LIke the Frunk liner!Came across these today: https://www.tesmanian.com/collections/ford-mustang-mach-e-accessories
Are your window deflectors doing any better now? I've been thinking about ordering a pair.Removing the thin plywood tray to put in the cargo mat now explains why the dealer installed mat doesn't fit (about 1/4" longer than needed on top of the plywood removable floor). Going to swap those out now!
Also the window deflectors are touchy - my driver's side is slightly warped and prevents the window from going up correctly. Going to have to heatgun it or replace.
California test: With all windows closed, no sun shade above, my Mach E stays cooler than my Kona Electric. The windows/windshield and the roof glass on the Mach E has good tint and good IR reflectance.That sunshade may come in handy
I'm still waiting to see how this looks in a picture or video before buying itIs anyone planning to add these sport stripes? I have not decided to get a Mach-E yet, but I think I may go with carbonized grey and the black stripe. Not sure about the side ones. The back piece could look really good but they don't show it in the photo-shopped car. Wish someone would do theirs first and share pictures!
That's because it's made to fit with the floor in the lower position.Does yours fit? Mine seemed like it was too long because I had to bend the back part up to squeeze it in. I called ford to see if they know of the issue and have a fix... I'll be taking it back to the dealership until they can figure it out.
Yeah, it would be nice if it was designed in a way that would fit properly in both positions.I wasn't aware there was a lower position of the floor. I'll take a look at it.
Update 2: Found out what you meant. It will look like this in the lower position. I'm not a huge fan of it being designed to fit like this. I attached how it looks in the down position, different than how @SOLIDAge and I had it before.
Q: If you need a flat layout with the seatback folded down, can the protection mat fit under the tray in the higher position (so as not to catch the lip on the rubber)?I just fixed mine - the stock cover goes into the well (below the support posts), then everything fits correctly. Photo of the wrong installment by dealer (IMG_6487), and then the correct placements for both items. Much better
