Jake
Jake
Wentzville, Mo
2021 Mustang Mach-e Premium standard range awd
USPS Letter Carrier
Oh I agree the sliders suck. I'm going to withhold judgment until I play with the new stuff.
The dial works ok, if you press too hard you can mute music while you’re changing heat, but it is a better way to control temperature of the heated seats. HVAC system, etc…
Neil4Real
That’s new functionality I haven’t seen anyone mention. Pressing the knob in, not the power button within the knob, mutes the audio? I wonder what the point of that is since the power button already does it, more obvious since that’s how other cars do it? If you’re adjust the HVAC on the dial and press the power button in the middle, does it turn off the HVAC or still just turn off the audio?
scoopman
Bay Area
if it does that it’s a change, long press in the original interface goes to calm mode.
Jake
Jake
Wentzville, Mo
USPS Letter Carrier
I’m assuming audio. It was an accidental press, I can’t say I didn’t lumber over on to the center button. Just adjusting heat with the knob and inadvertently muted audio.
JAD1075
Josue
PR
Mach e
Greetings, my mach e was updated manually because it was not done OTA, but the screen or UI update did not change. Is there an update that they omitted so that it can update to the most recent UI? I would appreciate any information you can provide. Thanks in advance. My vin number is #3FMTK3SU1NMA39222.
