Testing Cabin Air Quality During Wildfire Smoke
With Canadian wildfire smoke becoming a more frequent and persistent problem each year, it’s worth considering how it affects air quality inside vehicles, especially on heavy smoke days. To investigate this, I tested particle levels in my cabin using a portable particulate matter (PM) sensor while driving through smoky conditions.
Yesterday we had moderately bad air quality (AQI 100+):
Ford Mustang Mach-E Testing Cabin Air Quality During Wildfire Smoke wildfire_smok
Ford Mustang Mach-E Testing Cabin Air Quality During Wildfire Smoke Screenshot 2025-06-12 at 9.18.23 AM
Keep in mind I'm using Ford's premium cabin air filter, the micronAir proTect, which is designed to capture smaller particles like diesel and wildfire smoke. Particle counts are measured in micrograms per cubic meter (µg/m³), which differs from the Air Quality Index (AQI) commonly used by the public. Also, the sensor I used hasn’t been calibrated or validated yet, so the actual levels might vary slightly.
The outside particle count was about 32–36 µg/m³ (PM2.5; other sizes were similar), roughly corresponding to an AQI of 100 (orange, unhealthy for sensitive groups).
Unfortunately, due to an unforeseen glitch, only a small portion of the data I collected was saved, so I’m unable to show the graphs I had planned (perhaps another time).
Cabin Filter Performance
  • HVAC AUTO Mode: With the HVAC set to 72ºF on AUTO 2, cabin particle levels stabilized between 7 and 12 µg/m³, corresponding to an AQI below 50 (good air quality).
  • Recirculation Mode: Turning on the recirculate function (which stops outside air intake) dropped particle counts to around 0.5 µg/m³ over 30 minutes, indicating very clean air. Usually, the HVAC system cancels recirculation after some time to prevent fogging, but since the weather was mild (60ºF), it didn’t cancel (recirculation typically lasts only 5 minutes in colder weather). However, CO₂ levels inside the cabin rose to about 2000 ppm over time.
  • Defrost Mode: Selecting the defrost function sucks outside air at higher speeds—a worst-case scenario for the filter. Particle counts increased to 8–14 µg/m³, still representing about a 65% reduction compared to outside air. This is less than the filter’s stated 95% efficiency, but that figure is typically achieved only at very low fan speeds.
  • Recirculation Recovery Time: Switching back to recirculate mode, it took about 5 minutes at high fan speed for cabin particle counts to drop to 1.0 µg/m³, as expected. I like to call this “air purifier mode,” since it functions similarly to a home air purifier in how effectively it cleans the air inside the cabin.
Recommendations
If you're dealing with wildfire smoke, do these two things:
  1. Install a premium cabin air filter capable of filtering small particles (PM2.5).
  2. Use the recirculate button whenever outdoor air quality is poor.
Keep in mind that the recirculate function may automatically cancel after some time, so check every 5–10 minutes and reactivate it if needed.
Conclusion
Overall, the HVAC system and cabin filter performed well in reducing airborne particles during wildfire smoke conditions. Even with moderate outdoor pollution levels (AQI ~110), the system consistently maintained “good” air quality levels inside the cabin during normal operation. When recirculation mode was enabled, particle counts dropped to near-zero within minutes, demonstrating the HVAC system can function like an air purifier when used strategically.
These results suggest that even without specialized equipment or modifications, most modern vehicles equipped with a quality cabin air filter can offer significant protection against wildfire smoke. While the filter didn’t achieve its advertised efficiency under high airflow conditions, it still reduced particle levels by over 60%, which is meaningful for anyone with respiratory sensitivities and improves overall comfort on smoky days.
For those living in areas regularly affected by wildfire smoke, simply using the recirculate function can significantly reduce your exposure to harmful fine particulate matter, which helps protect your lungs and health during wildfire smoke season.
Dana3502
Dana
Des Moines
2024 Mach-E
Good info. Thanks!
This is another reason why I hate the HVAC controls being on the touch screen. You don't know when the recirculate gets turned off. I was sitting at a stoplight while the guy beside me had his window down and was smoking. Suddenly I could smell his cigarette smoke. Sure enough, the darn recirculate had turned itself off. Grr!
I've been using that filter for a while now in Hawaii's island's vog-addled skies courtesy of Kilauea and Madame Pele. VOG is SO2/SO4 and a bunch of very fine particulates. Vog sucks. The filter is great.
nzwayne
Wayne
Burlington, ON. Canada
2022 Mach-E GT Performance
Hardware Product Manager
I installed that premium air filter FPP89 on my 2022 MME GT-P and 2024 Lincoln Corsair GT. Around the Toronto area and especially with the wildfire smoke that was present in last few weeks, the cabin air was absent of any smells, stenches. We use HVAC Auto 1 mode on both vehicles.
My wife who is a chef, can determine "blind-folded" all different herbs/spices, also noted "nothing" present inside the cars cabins after the filter change. The slam dunk one day was a truck in front of us drove off from stop light, total smoke everywhere, couldn't see visually forward for a few seconds...no smells in cabin though. the extra cost of this air filter and time to fit, well worthwhile to add to a quality drive!
ChrisO
US
Speaking of the Recirculation Mode, has anyone got the Mach-E stay in this mode? Whenever I have tried it, it has switched out of that mode within a couple of minutes. And it also a royal pain that you have to go to the other window just to turn it on.
On the other hand, since changing out the air filter for the premium one, we really haven't needed this. Haven't smelled any smoke or other nasty smells since we put it in. It has been great!
Vgkfan
Keith
Nevada
Mine used to do that but now will stay in recirculate mode until I change the fan speed. I thought it was any change but tested it changing temp and it stayed on.
Bumping this since concentrated wildfire smoke is currently affecting a huge swatch of the continent from Ontario to New Jersey. There have been extremely high AQI 500+ readings in many areas. The unprecedented readings in northern Minnesota and Wisconsin have been the worst in the states' record.
Ford Mustang Mach-E Testing Cabin Air Quality During Wildfire Smoke Screenshot 2026-07-16 at 2.45.57 PM
As a reminder, if you're dealing with wildfire smoke, do these two things:
  2. Close windows and use the recirculate button whenever outdoor air quality is poor.
Doing the above has been working for me. Particle counts stay low enough inside the cabin.
After more testing, in hot weather with A/C on it does not seem like recirculate auto-cancels. It has stayed enabled for 30+ minute drives. That is good for smoke, but can cause CO2 buildup with time.
470 today.
Recirc, Auto Off.
MnSparty38
Twin Cities, Minnesota
2022 Mach E Premium AWD Ext
Any recommendations for current air filter brands? The premium one on fords website in the OP link says it doesn’t fit the ‘22. Had a 500+ aq rating this week here in MN.
STP at auto zone is $45.
Their website is wrong, FPP89 fits just fine.
FYI, that STP filter is a rebranded Pureflow for twice the price.
ARK
Los Angeles
'21 Premium SR AWD
*snip*
When the Mach-E first came out, recirculate wouldn’t stay on but would cycle off after some time. There was some complaining about this on here, and I want to say ever since mid or late 2021, Ford did an update where recirculation stays on now if you deliberately enable it, at least as to the temperatures I see in Los Angeles year-round.
rhexis
West Chester, PA
2025 Mach-E GT
moved from california to the philly suburbs 25 years ago and as far as i can recall its only been last year and this year we got hit with this canada wildfire smoke. last month i installed this air filter and it seems to be working well although i havent measured particulate density inside the car. cabin air filter
