shark
Texas
Mach E GT
I do not...but you're saying this is after a "Clear and Retest"?
Yes after clear and retest. I am running the APIM update now. Hopefully all green when it's done.
Mike G
N. AL, USA
Well at the end of any programming session I turn the car/truck completely on and do a clear and retest to make sure everything is green before I disconnect and shut down. Sort of starting off with a clean slate and to make sure I have no persistent faults.
shark
Texas
Mach E GT
Well I finished the APIM update and all modules show green now, no codes. However after installing the APIM, the system showed me a GWM (Gateway Module A) update that also required writing files to the USB. After it went through the whole update process with the USB it displayed:
The module configuration has failed. Would you like to retry?
I tried again and early in the process it displayed:
com.sun.xml.internal.ws.client.ClientTransportException: HTTP transport error: java.net.SocketTimeoutException: connect timed out
I don't have any more time to work on it this morning as the wife needs the car, so I stopped there. I checked the SYNC 4 version on screen and it now shows Revision: 498 (previously on 176). Does anyone know what is up with the GWM A issue?
Thanks
Mike G
N. AL, USA
Thanks
Yeah...it's Sunday server maintenance time....it will be back up in probably an hour or so. You just got caught out at the wrong time....
Mike G
N. AL, USA
FDRS is back up now if you want to have another go.
connoisseurr
Connor
Northern VA
22 Rivian R1T, 23 Tesla MYP
IT Engineering
I was hoping the Sunday AM FDRS maintenance period would include a new wave of available updates for us owners. I was too optimistic ?
tobin1920
Anthony
PA
2022 Mach-E Premium AWD ER
(edit: '22 premium w/build date of 2/19/22)
I was feeling optimistic after reading reports of success for 22's and the latest APIM, so I grabbed a 2 day and settled in to run some updates tonight... Got connected up and saw a handful of updates, including GWM available so I thought that was a good sign, but I ran PCM first which also kicked off the SOBDMs. After they were done, the GWM was no longer presented, and no APIM to be found.
I'll certainly check again throughout the day tomorrow + Tuesday. A little bummed but oh well
connoisseurr
Connor
Northern VA
IT Engineering
I'll certainly check again throughout the day tomorrow + Tuesday. A little bummed but what can ya do? (except wait patiently like almost everyone else)
What’s your build date?
scoopman
Bay Area
Same experience I had. SUCH A TEASE!
shark
Texas
Mach E GT
Tonight I plugged in and it showed another APIM update, this one was 5GB in size, followed by GWM, and TCU. All modules are now up to date and SYNC is now showing revision 539. I also received a Ford Pass notification about some Alexa integration.
Arjan
Arjan
NL
Ford Mustang Mach-E GT Performance
Is the new Sync 4a available in FDRS ? I am reading some mixed messages about that.
