Mike G
- Mike
- Mar 27, 2022
- N. AL, USA
- '23(J1) Mach-E GT-PE, '22 F-150 Lightning, '24 Bronco HLE 2Dr
Above updates all done. Programming time was 15 minutes exactly.
It all went without any drama. At the end after the last module in the script was updated (sequence was PCM, BECM, SOBDMC, SOBDM) after programming where you expect to be returned back to the main screen there was an unusually long delay, with some sort of error that flashed up at the end after it was all completed. I was returned to the available software screen and decided to run the network test again just to check and see if anything popped in.
Nothing new showed up but a bunch of modules that a second ago had been green were now orange. So I cleared and retested and ended up with everything green except the VDM. So I thought I'd try a tip provided by @Skyman63 and before clearing the DTCs again I cycled the drive modes through all the settings and then left it in unbridle the way I normally drive, and then cleared and retested. It stayed off this time. I don't know if it will stay off now or just come back later. We'll see.
After closing FDRS that error that flashed by became clear by a dialog box informing me that FDRS had run into an unknown error that was going to be reported to the FDRS team. So...I've got that going for me.....which is nice I guess.
No modules were harmed during this event. Car is happy/glad and works fine.
Note for clarification: The VDM DTC problem only affects GT-PE trim level cars as they are the only ones equipped with Magnaride.
