Understanding air conditioner compressor operation
Here's the setup:
On a drive yesterday, outside temp is 73F with light drizzle. It would be a perfect day to be outside other than the light rainfall. I set out with climate control on, AC off, and temp set to "Low". I expected this to simply run the fan and pull in outside air.
Within minutes, I'm freezing in the car. Up the temp to 75, then 78. Still very cold air coming out of the vents. I checked the settings to be sure the AC was still set to off.
Had it not been for the rain, I would have simply turned off climate control completely and opened the windows.
The only thing I see in the manual is this:
Note: Under certain conditions, the air
conditioning compressor could continue to
operate after you switch air conditioning off.
Not helpful! No description of those "certain conditions".
Any insights, thoughts, other experiences?
Thanks!
ZuleMME
Zule
Denver, CO
21' Job1 P4X MME, 22' MYP
Implementation Engineer
When running the defroster the A/C is a required element and it runs to remove the humidity from the air. Normal operation.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
In those conditions I simply leave the temp as is and make sure A/C & E-Heat are both off. That seems to do the trick--no need to set to "low" (it is possible the "low" setting also forces the A/C on given that you're telling the car to be a fridge).
Defroster was not on.
What you say is true - AC runs when calling for defrost when above freezing. That's been common in most all cars for years. However, I would say it's not always required. I'd like to have the option to run the compressor only when I want to. The best set of climate controls I've ever owned was in my 1988 F250. Everything was controllable by me.
I thought that might be the case, but expected it to turn off once I set the temperature above outside ambient.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
The compressor will also run to cool the battery if needed as well. Possible a software bug is letting the inside AC stay on if the compressor is on to cool the battery?
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
“Certain conditions” may also include high humidity as air conditioning is also dehumidifying. Perhaps the car didn’t want your windows to fog so it left the dehumidifier on. Then when you set the temperature to something something Kelvin it said “OK, here we go!”
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
Seems unlikely the battery would need refrigeration cooling in the ambient temp OP listed. But hey, you never know. ??
