Uneven panel gap between glass roof and tailgate
garfieldorlando
Mustang Mach e
Picked up my RWD extended range MME, really love it. It is fast, sexy, and quiet. Everything works perfect so far even for PAAK. However I do notice an unusual panel alignment issue which bothers me a lot. It is obvious enough that you cannot ignore it. The gap between the end of glass roof and tailgate is quite uneven. The right side is much higher to the left side. Attached the photos below (apologize for the messy garage). It looks to me the right side around that clip the glass roof is not fully flushed down. Dealer checked and confirmed the tailgate is aligned perfectly to the frame. Sadly they cannot do anything and told me it left the factory thus must be within the spec. However, given a $60K price tag, I have to say I expect much better build quality. This defect reminds me the early age Tesla MYs... Is this fixable? Anyone else has the same issue? My worry is that the right side of the glass roof may suffer the stronger pressure comparing to the left side and at some point it may crack out...
agoldman
Charleston, SC
GT Cyber Orange
They should be able to adjust that. Should being the operable word.
garfieldorlando
Mustang Mach e
I would only be concerned about tailgate alignment, and you already had that checked.
Tailgate seems aligned properly, which leads me think it is the glass roof installation defect. Well, probably it is indeed within the spec, though for such an expensive car the allowed mis-alignment should be much tighter. Not the case from I see sadly..
agoldman
Charleston, SC
GT Cyber Orange
tell that to Tesla while you're at it.
garfieldorlando
Mustang Mach e
True, early MYs have similar issues, just I expect Ford to be tougher on quality control. Given how obvious the issue is, I have to say I am disappointed, from the quality perspective. Car is great and I really like it, that's why I didn't refuse the delivery. But again, I stopped laughing at Tesla now as what I saw is no difference to those early MYs.
ClaudeMach-E
Claude
Quebec Canada
Mustang Mach 3- Tempo- Malibu(3)-Actual Kia Sportage AWD
Yes I thought I saw that on some picture too and woory's me a bit. For sure I'll check at my delivery.
SteelMach
2021 Mustang Mach-E
Contacted Ford through facebook message. A case is created and escalated to internal SUV service team. Gonna update as soon as I got the response.
Hopefully they come through and make it right. That is not an acceptable panel fit, for sure.
Dealers will say anything to get out of work sometimes. I've found their favorite response to any squeak/rattle concern is "we didn't hear it, sorry."
sockmeister
Pennsylvania
2021 Mustang Mach-E4x
SW Engineer
Looks like the hatch door needs to be adjusted slightly higher on the right side, still. I'm not sure the glass roof is the problem. Try bringing it to another dealer for a second opinion there; they should definitely be able to adjust it.
garfieldorlando
Mustang Mach e
@SteelMach @sockmeister Thanks for the suggestions. At this point I will wait for confirmation from Ford that this is fixable and their recommendations. I have spent over 5 hours Tuesday with dealer before getting "nothing can be done, it is within spec" answer. It is painful and I am afraid I go there again likely I will waste another couple hours for nothing.
If the car is quiet, the liftgate closes properly, easily and without rubbing anywhere, you're probably good to go. File a report with the dealer as you did, and stay in touch with them about it ocassionally. Keep an eye on it, but I bet you're fine, as @RonTCat said as well.
And I'm jealous. Mine is on day 10 of its 64-day journey to me.
JellyBelly
Kris
MME RR FE
There are lots of height differences on the roof of the MME. Lots of different angles and the sharkfin antenna sits on a curvy triangular piece and its slightly higher that the glass roof as well. On paper looks great but very hard to make and assemble in alignment - not to talk of the differences folks already noticed around the glass roof and the front and the sides.
I assume Ford has inspected at factory for all this stuff but there is no way to tell if its OK or not ok for us unless we get a few cars of the same trim and do a comparative measurement.
