Update Not Successful
itsthenewdc
Damian
Orlando, FL
Line Producer
Over the last couple of days when entering my car I’ve gotten Update not successful displays when the car boots but see no signs of an update pending. Nothing in Settings > Software Updates and nothing in Ford Pass app about updates or even the failure. Is this a bug?
Ford Mustang Mach-E Update Not Successful ECBA88E6-C6B7-4D2C-AEA8-CB688FFEB7FE
Ford Mustang Mach-E Update Not Successful CA67C9C1-880D-4261-AB76-E0E7D73B09EE
Gimme_my_MME
Dearborn
With automatic updates turned on you won't see any sign of an update pending. It will just keep retrying in the background and hopefully eventually install in the background as well
Charlotte Area
Mach-E Premium Space White
It might be failing because you aren't using dark mode... I'm kidding about the failing, but please turn on dark mode. Your eyes will thank you :)
Sorry you are having issues with updates, I am still stuck on 1.7.1 but my car no longer tries to update
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Try setting an update schedule for sometime late at night when you're not using the car.
Like Sun - Sat at 3:00am.
itsthenewdc
itsthenewdc
Damian
Orlando, FL
Line Producer
That’s what I’ve had it set at, but at 1:00am.
itsthenewdc
itsthenewdc
Damian
Orlando, FL
Line Producer
I got the 2.3.0 update (coming from 1.7.1), but only seem to have some of the functions/features discussed.
  • I don't have Blocks & Tiles
  • CarPlay doesn't go fulls-size
  • I don't see Speed Sign Recognition
  • Volume bar is still vertical
  • Multi-day scheduling still only allows me to select one day
  • Notes app sometimes say it's disabled due to motion, even when stopped
Things I did notice I did get added..
  • Notes app
  • "OK Ford" added and works
  • Tic-Tac-Toe added
  • Calculator added
Anybody else have this issue?
Ford Mustang Mach-E Update Not Successful IMG_2190
Ford Mustang Mach-E Update Not Successful IMG_2191
Ford Mustang Mach-E Update Not Successful IMG_2192
Ford Mustang Mach-E Update Not Successful IMG_2193
Ford Mustang Mach-E Update Not Successful IMG_2194
Ford Mustang Mach-E Update Not Successful IMG_2195
