Using a 12v Car Power Inverter on the Mach-E
Mathington
Canada
Mach-E Premium SR AWD
I have been thinking about getting an AC car power inverter that plugs into the 12v sockets in the front and rear of the car. I thought that this could be useful while camping or during road trips to power things like laptops, phones, charging portable battery packs, etc.
I am wondering if anyone here has tried this yet and what limitations there would be on the plugs so I make sure I get the correct type of inverter.
I was thinking about getting something like this on on Amazon
BlueDvlTxn
Justin
North Carolina
2014 Explorer Sport, 2017 Fusion Energi
I had a similar idea a while back - but then decided I could charge everything I needed off USB (type A or C) - so got this from Amazon No need to convert DC to AC just to convert back to DC. Many newer laptops charge off USB C, and this had enough power to support my needs. Works like a champ!
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
The 300W inverter would work. Just don't expect to make a pot of coffee with it.
We have an inverter that works fine, no reason any wouldn't unless you exceed the outlet's output. Never had a laptop that charged off USB...
Mathington
Mathington
Canada
Do you happen to know what the output limit is for the outlet?
From the manual:
POWER OUTLET PRECAUTIONS
When you switch the vehicle on, you can use the socket to power 12 V appliances with a maximum current rating of 20 A. Do not use the power point over the vehicle capacity of 12 V DC 240 W or a fuse could blow. Do not plug in any device that supplies power to the vehicle through the
power points. This could result in damage to vehicle systems. Do not hang any accessory from the accessory plug. Always keep the power point caps closed when not in use. Do not insert objects other than
an accessory plug into the power point.
To prevent the battery from running out of
charge:
• Do not use the power point longer than necessary when the vehicle is off.
• Do not leave devices plugged in overnight or when you park your vehicle for extended periods.
Mathington
Mathington
Canada
From the manual:
charge:
Thanks for the info! 240w limit it is, good to know this.
hawkeye3point1
NH
Badger_Prof
Randy
Good idea. The same company also has a higher power option for a few dollars more: https://www.amazon.com/dp/B09GJTF54...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
this is if you use a 'power outlet'.....
if you use the 12v connection points in the Frunk, and the MME is 'on', the dc-dc converter can safely support up to 160amps from the HV battery to support energy export. Probably best to keep it under 1500watts, but ok to handle a little more for short periods.
Plenty to run a teapot, or an induction cooktop, or a bunch of lights, computer, etc in the house as an emergency generator.
