Wheel Sizes
kdryden99
Richard
Montreal Canada
Smaller wheels is pointing to more range and therefore may be an option for a winter set. Would be a bit hesitant about 17" until you see someone bolt a set on.
Itll have to specialized in such a way that the tub of wheel would stright instead of flared to clear the calipers. If i get the car in july hopefully some one will create a set like they did for the model 3 performance.
But man they look awefull.
Yeah, I'm pretty sure I am going to take the aeros off of my RT1 for that reason. The Select's aero wheels look pretty good, but the RT1's look a lot like the Tesla Tonka-truck-style aero's. Tesla's wheels look pretty good underneath, and I'm hoping the MME's do also. The only question is if they make a hub cap like Tesla or if the wheel already has one underneath the aero.
trutolife27
Bourbon Country.
there will be a lot of after market people making. tsportsline.com made some great ones for tesla. Some are limited to like 100 sets. they keep the mold if they need to make a repair but other than that they make a special limited amount. I bet they make some ford ones maybe.
This is the only view I've ever found that gives some hint of what the CA Rt 1 wheel looks like.
Seems to be the second one from our left.
Ford Mustang Mach-E Wheel Sizes EnEWDz_XYAAJhNK
REALLY hard to see what's going on in there, but I'm thinking MAYBE it looks like this:
Ford Mustang Mach-E Wheel Sizes se_u3_b_pdpfulla
ajmartineau
Washington
2021 Mach-E
What is that bolt pattern, 114?
Shayne
Northern Ontario Canada
2021 MME4x Prem
You mean the one in the middle? If it is Ford's max range wheel it may be a contender for a winter set? I am sure they will come out with wheels with the right offset that bolt onto the ford. I was thinking of putting a smaller more aero wheel on in the winter. Really don't care what they look like more how they go and a bit more range and a higher wall to cut through snow is a go.
If the vehicle shows up this winter I will start by running the A/S 19" on it and see if that works. I know for 30 years A/S have on a 4x4 pick up of the same weight. My 4x4's have always had manual linkage to the transmission. I presume the computer traction control will work a bit better than a stub drive shaft and another differential. Bit more power and torque than the v8 I have had so whisper may be good in the snow? Mellow with no fast movements ;).
Yes, I've seen that shot from the back but it's really hard to tell the spoke pattern. If you have seen shots from the front side there is definitely a 5 spoke raised design on them, so I don't think the one above is it. Like you said it is really hard to tell. Almost anything has to be an improvement, as long as I can get a center cap for it.
ajmartineau
Washington
2021 Mach-E
Iirc I read 5x114 in something official but can’t find it now. I’ve been searching for it from the my phone so it’s less effective.
kdryden99
Richard
Montreal Canada
I am really surprised this info isn't in the manual
smart185
Serge
St-Eustache, Québéc
Explorer
retraité
That wheel page shows offset 38-53... I'm wondering where they got those numbers. That's a fairly large range. I wouldn't be too sure yet that everything in that range will fit well. Sure, the wheel might bolt up, but if you put a 38mm offset wheel on a car designed for a 53mm offset you may end up with problems. Plus, you don't know what the load rating of the wheel needs to be. I randomly chose one of the wheels listed on that page and it had a load rating of 1600. No way will that be strong enough for an E. The wheel load is determined by taking 50% of the heaviest axle rating of the vehicle (GAWR – gross axle weight rating). Example; if your heaviest axle weight rating is 3800 lbs then your wheel load requirement would be 1900 lbs. I don't know what the GAWR of the E will be, but I'll bet the rear axle is rated higher than 3200 pounds, probably closer to 3800.
An offset of 15 mm represent 9/16 of an inch. Since Mach E GT will have 20'' x 8'' and Premium have 17'' X 7'', a wheel with 38 mm offset will fit. That will mean the exterior of the wheel will be about at the same location for a 18'' X 7'' than a 20'' X 8''.
This is why there a gap of 15 mm to accomodate the GT whelles.
Puisque 15 mm est égale à 9/16 de pouce, une roue mesurant 17'' X 7'' sera positionnée à l'extérieur du véhicule presqu'à la même place qu'une roue de 20'' X 8''.
De là la raison pour laquelle il y a une différence de 15 mm entre les 2 roues.
