When Ground Clearance Rocks Your World
MyTH
Boston Area
MME, Bolt EUV, Model Y, Lightning
As early EV adopters, my wife and I were excited to reserve and order a Mach-E in 2020 and take delivery of one of the very first 2021 models to arrive at the local dealer. That vehicle was always a favorite and gave us several years of great service. But all good things must come to an end; this is the story of the end and a new beginning.
Did you ever wonder what happens when a 5.7 inch ground clearance meets a 6 inch rock? Read on...
Early one Saturday morning, a rock sat near the middle of a narrow country road, just around a blind turn, apparently having rolled down the adjacent hillside. There was no time to stop, but this wasn't a very big rock -- looked like it could be easily straddled. BOOM! Um, maybe not.
Despite the loud noise and being momentarily lifted up, the car continued to drive normally, not only that day but for several months and several thousand more miles. We had forgotten all about the rock by the time a warning appeared: Stop safely now. It happened on a busy road in Connecticut, over 100 miles from home, while we were stopped at a red light.
Stop safely now? Well, we were already stopped. When the light turned green, the car wouldn't move. The hazard flashers worked, but many people honked and gave us dirty looks. AAA said they could have a tow truck there in 90 minutes. Ford's emergency roadside assistance said they would take 2 hours and warned us it wasn't covered by warranty and would be expensive. That was a long time to sit blocking traffic, but eventually, after turning the vehicle off for 5 minutes, it started and drove normally. We cancelled the tow truck and drove straight to the nearest Ford dealer, who said they were busy but could look at it in a couple of days.
Really? No emergency help available? Hours for a tow truck, days for a mechanic? Um, OK. We decided to limp carefully onward, staying in the right lane, expecting the car to stop at any moment, and actually made it the whole way home without further incident. The local Ford dealer scanned the fault codes and said they knew what was wrong, something about a High Voltage Battery connector. When the part they ordered came in a few days later, they put the vehicle up on a lift and called us with some grim news: there was frame damage. Had we been in an accident? No, the car just shut itself down while waiting at a traffic light.
OK, how much is the repair going to cost? I was expecting a few hundred dollars but braced for something major like $1000. When they got back to us with an estimate, it was more bad news: the part of the frame that connects between the left and right front wheels had a hole in it and needed to be replaced, costing at least $6000. Wow, a hole in the frame? How could that be?
It got worse. There was also impact damage to both the front and rear drive motors, and the front one was leaking oil. Oh, and there were some small dents in the housing of the main High Voltage Battery -- no way to tell if there was meaningful damage, but the battery really should be replaced, just in case, adding at least $29,000 for the part, plus installation labor. All told, the repairs to a Mach-E that still looked new and drove fine were going to be about $40k, twice the vehicle's book value.
Bummer. We filed an insurance claim and set about finding our next EV. After a bunch of online research and test driving many great alternatives from Audi, Acura, Genesis, Porsche, BMW, and others, we ended up back at the Ford dealer for a new 2025 Mach-E. It's black, just like the old one, with the same plate number even. Now we have ventilated seats and a heat pump. The frunk is smaller, and the gearshift is in the wrong place, but we still like the car as much as ever, barely noticing it's a different car.
Kudos to Ford for building a vehicle that still stands up well against the mounting (and significantly more expensive) competition, 4 years later, with only minor design tweaks. Would we buy it again? Why, yes. Yes, we would. I do wish there were a better answer for possible battery damage than replacing the entire $30k battery pack. I'm also pretty annoyed at Ford's disallowing any sort of transfer or credit for our prepaid 3-year BlueCruise subscription on the totaled vehicle, but that's a separate thread.
Ford Mustang Mach-E When Ground Clearance Rocks Your World FrameHol
Ford Mustang Mach-E When Ground Clearance Rocks Your World BatteryDamag
Ford Mustang Mach-E When Ground Clearance Rocks Your World StopSafely
Anytime something lifts the vehicle up, you need to stop and get it inspected ASAP. You're lucky that piece didn't separate and cause you a catastrophic failure at 70mph.
GreaseMonkey
Chicago, IL
24 Mach-E GT
Wow, you drove it several thousand miles like that? You're lucky that front subframe didn't decide to finally snap in half because the wheels might have collapsed, you would lose all steering ability, and could instantly veer off the road and crash.
In short, when driving an EV, if you hit ANYTHING in the road, you should get the underside of the car and battery inspected ASAP for damage. If the hit is so severe the vehicle lifted, you should pull over immediately and do a roadside inspection. In some cases the battery will immediately start on fire after a debris impact, so it's a serious thing.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Glad it worked out ok. Hopefully your insurance gave you a decent payout and didn’t raise your rates. And I’m really glad you got lucky with the frame damage not causing a serious accident!
Tomm
Tom
Davis Ca
2023 Premium
Surgeon
Impressive hole. I wonder if a cursory inspection by the side of the road would have seen that. Especially with the underside covering.
dan_meh
Daniel
Alexandria, VA
Technical Writer
Impressive that the car managed to drive like that. Glad you are ok! 😰
Dana3502
Dana
Des Moines
2024 Mach-E
With "ground clearance" being in your title, I was sure you were going to tell us that the trip back to Ford resulted in you buying a Lighting. :)
MyTH
MyTH
Boston Area
Yeah, I actually do have a Lightning, and that rock would have been no problem. I really like it, but the wife complained about having to drive the truck while we waited for the Mach-E to be fixed - and then waited to get a replacement.
We were definitely lucky the frame damage didn't lead to a crash. The hole wasn't visible until the vehicle was up on a lift. Once we saw the damage, we never drove that car again.
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Shoulda gone with Rally. For the clearance.
AustinMachE
Frank
Austin, Texas
2024 Mache Premium Extended Range RWD
One of the side benefits experienced when swapping the stock springs with the Rally springs on my Premium. Gained at least another inch in clearance and made it easier to get in and out of the car.
SeattleSteveMe
Seattle, WA, USA
2022 Mach-e Premium AWD EXT
Stagehand
Was that a difficult swap? Are there other parts needed as well?
MellowJohnny
Christian
YYZ
Solution Architect
AustinMachE
Frank
Austin, Texas
There was some uncertainty that my mechanic had during installation regarding the spring bowing that Markboris was able to clear up. Otherwise, nothing else came up.
As for parts, I say that depends on your trim. I have a Premium RWD ER, which is more rear heavy, so would have sat with a negative rake with the new springs. I ended up getting a pair of 3/8in Steeda Mustang spacers to even out the rake. I think if you have the standard range or AWD, you probably wouldn't need the spacers.
