I don't think you are an expert on the frunk button to the point you should be giving out advice? Have you even tried the frunk button to date? ;)
No, but I am an expert at rebooting sync to try to clear abnormal behavior ?
kwalkerj51
Keith
Ivins
2021 Premium Mache Ex Infinite Blue
Still no frunk release ?
I took my ME June 2021 build into dealer said the virtual frunck button dissapeared. They downloaded new software to create button next to trunk button and also your door code + 78 will open fronk. Finally!
Lol even though you never HAD a “virtual frunk button”?
theriddler
Patrick
Louisville, KY
‘23 F-150 Lightning Lariat Extended Range
Had to run the defrost for a moment to get it to charge.
It's not on the IPC but the charge rate is available now. That should make a few people happy.
Where do you see that screen? I don't see a screen like that in my FordPass app.
theriddler
Patrick
Louisville, KY
ah
You have to be charging and click the button on blue bar at the bottom of the screen.
thanks...I just keep looking at it after the fact and was wondering.
superdave80
Santa Rosa, CA
2022 Mach E Select SR RWD
This is normal for most charging station. We are waiting for Ford to include this data in the car itself for chargers that don't show rate.
I guess this is progress, but what's kind of stupid is that this data (charging rate) is:
1) Clearly available from the vehicle's computer
2) Able to be sent to Ford servers to send to our phone, but
3) Is still not able to be sent to the car's screen that is SENDING the data over a cellular connection?
I am just continually baffled by Ford's insane need to hide useful information from us.
kennelh
Louise and Ken
Northern California
About six months ago I found an API access point endpoint with charging info, but never went farther with it for the Android widget. Subsequently Ford locked down parts of the API, but I checked today and this one still works. I'm going to check whether it's where the charging rate info is stored. I doubt the FordPass app is calculating this since it can't be continuously pinging the car.
Follow-up: I was able to find another API endpoint which I hadn't documented very well. Confirmed today that it contains the current charge rate (in watts) and total energy delivered (in watt-hours). I plan to somehow add this info to the Android widget in the future.
sundan
Finland
Mustang mach E
Pretty well Frod was able to depress me when I read that my car has been updated to 4.2.1.2 I went to see how the screen has changed but nothing new has happened. In the USA power up updates there are new keys etc etc but in Europe ZERO then absolutely NO changes. THANK YOU AGAIN Ford!
Ford Mustang Mach-E 📲 FordPass App 4.25.0 released w/ Charge Rate Indicator! 4.2.1.2.jpg
SWO
MD, USA
I have no comment except that spelling bees in Finland must be entertaining. :)
