McSquashy
Josh
Massachusetts
I was about to say I don't have anything like that (climate controls) on my 5.7.0 installed version. But it didn't occur to me that those controls only appear after you start the remote climate feature. After starting the climate remotely, I do have the climate controls.
I just tried the remote climate turn on from the FordPass app from my Pixel Watch 3 for the first time just now and all it does is honk the horn a couple of times. The climate never turns on.
I spent an hour on the phone with FP tech support yesterday trying to figure out why I'm not able to download the companion app onto my PW3. It won't even show up in the Play Store. We went through every troubleshooting step and still couldn't figure it out.
hack-e
Austin, TX
2022 Prem AWD ER MME
Robotics Engineer
Are you
Are you in a beta tester for FordPass? If not, then maybe that's why.
McSquashy
Josh
Massachusetts
Are you
I'm not, but FP 5.7.0 shows it as being a feature when you first update. Also, tech support mentioned it should be available to download.
Ford Mustang Mach-E FordPass App 5.7.0 Released 1000006129
hack-e
Austin, TX
Robotics Engineer
I know the Apple Watch got it months ago, so not sure if this feature banner has been there since Apple Watch got the support. Regardless, I hope you get it soon. But I hope I can get to work properly in the meantime.
JeffGo
Washington, USA
2024 MME GT in Eruption Green
So a bit of an update - yesterday my 22 premium gave me a charge error fault from a grizzly-e charger. I was limited to only control the charge level setting in the car but it the app I was able to start it again to go to 100%. After throwing the error, I power cycled the Grizzl-e, restarted the car to clear the error and magically, all the features in my app are back. Home location magically reappeared, charge level setting reappeared and parked location now works. Either going to 100% did something ( I had done that before ) - or perhaps a back end problem was restored. Just thought I should update.
I have an Emporia charger and charged the same day. When I got in the car Charge Station Fault showed on the IPC, but the charge completed fine. So maybe a backend issue of some sort?
I charged last night, I'll check again. It did complete fine according to FordPass.
JeffGo
Washington, USA
FordPass 5.7 on iOS (I am in the beta). With this version:
The odometer reading on the Service page is not updated, seems stuck on the reading from the last charge. Owner dot Ford dot Com has the correct value.
After charging, FordPass shows ridiculously high values. Last charges 177 kWh (46.7 per Emporia); 142 kWh (48.7 per Emporia).
Haven't seen either of these bugs in previous builds.
Mauser
Canada
'22 Mach-e GT-PE Space White
I received 5.7 yesterday on my S21 and it shows the temperature adjustment
Well I'll be damned! I didn't know this was there. Game changer!! Thank you!!!
