10000 mile service...
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
10,000 service is tire rotation and a bunch of "inspect". Discount Tire does rotation for free.
I took mine in for this tire ratation and the cost was $49 dollars. that was the only cost of service for 10,000 miles. I think it was worth it.
LinkRS
Rich
Texas
2023 Mustang Mach E GT Performance Edition
I just did my 10K services on my 2023 Mach-GT Performance edition. Dealership charged me $160. Rotated tires, replaced cabin air filter, inspected and "filled" cooling system (?), inspected breaks, and installed some software updates.
Mach T
Mach-e
Can't we use our Ford points for 10000 mi service, which virtually makes it free?
shutterbug
Joseph
AZ
MME GB FE—Dead. F150L Lariat SR. 2024 MME Rally
You can, unless you used the points for something else.
Fremont Kid
Colorado Springs, CO
Retired IT
Yes. I did. However, knowing that tire rotation is the main activity, you can save points for other things.
Fremont Kid
Retired IT
Most people have paid around $50 for that service at the dealer. Discount Tire is a good option, just make sure the lift it correctly. It helps if you have your own pucks to take with you.
I agree! For those who have not purchased lift pucks, these are a beneficial investment. If your MME ever needs to be raised on a jack, the pucks are essential. Search the forum for more information regarding the pucks.
dalola
SE Ohio
sunsetridgecabinhockinghills.com
24 Mach-E P4X, 24 Bronco Big Bend Sas, 22 Maverick Lariat FX4 4K, & Hot Rods
Retired 🇺🇸
I actually prefer a spreader bar (placed between the puck locations) to raise one side at a time, then place jack stands under the puck locations. Works much better, IMO...
Fremont Kid
Retired IT
Never used spreader bars but...two points:
First, as long as the vehicle weight is dispersed sufficiently to not damage the battery rails, then all is good.
Second, carrying small pucks is probably more convenient and space-saving than carrying spreader bars. Using spreaders at home or a local shop makes sense, though.
All the best.
dalola
SE Ohio
Retired 🇺🇸
All the best.
NEVER lift on the battery rails, even with a spreader! Lift along the rocker panel rails, where the puck locations are.
steveg95
Stephen
Marion, IA
Ford Mustang Mach e
Should I do it? Is that required? Just hitting my first 10K miles.
My dealer charged $47. I thought it was worth it. I'm using a Lincoln dealer that doesn't specifically sell Mach e. I always tell the service rep that I have a paper on the seat of the car showing the proper lift points and make sure you don't do it wrong and mess up my battery.
I just had my 30k checkup. The service rep was chuckling when I got the car back. He had a new tech working on it who wanted to know what was involved in the 30k check on the Mach e, "Just an oil change". I laughed and asked how that went.
AllTheThings55
Mesa, AZ
2023 Mach E Select w/AWD
Professional Services (IT)
I called my local Ford dealer to make an appointment for my 10k service. I said not to rotate my tires because I just put on new snow tires. Her response was that unless I had some issue I wanted them to check, there was no point of bringing it in. I said "thanks, talk to you next year" :)
My dealership said the same thing.
Maui
Austin, TX
2024 Mach-E Premium
Software
They sent a mobile guy out for my 10k… used points. Beats sitting on the waiting room for hours
