12 volt battery charger recommendations
saj65
Bloomington, IN
2022 Mustang Mach-E
I bought a replacement 12 volt battery (BAGM-H3) from Ford dealer last fall using my points before they expired - it was built in July 2024. I plan to have dealer replace the original during 20K mile service, which should time out close to the end of its 3-yr warranty. The replacement will be at/near 1 year old, so I want to fully charge it overnight before service - recommended chargers/precautions would be appreciated? thank you.
JRSNoVa
Northern VA
2023 GT Performance Grabber Blue
That link shows all of Amazon's Battery Tender options. Any more specific advice?
I stated Battery Tender or NOCO. I said I had 3 battery tenders. How much more specific do you need? :wink:
JRSNoVa
Northern VA
There are more than 30 BT/NOCO units at that link. Are you saying any one will work equally well on the MME?
I have a 1.25amp and two 3 amp units. Any of the 3amps would be what I would buy again.
OrchidMania
Miami Beach
Grabber Blue Premium ER
Retired IT, School Math Volunteer
Ok. Call me dumb. I don’t understand what these are? To charge a dead battery or for regular maintenance and how ofter
if you can get access. My husband has been promising to add the battery access points for 3 years)
I recommend anything made by Clore Automative that has a dedicated AGM mode, such as the PL2310 or PL2320, or anything in the CHARGE IT! series (yellow triangle shape).
BatteryMINDer® Model 2012-AGM is also good as a maintainer.
Personally do not like NOCO 12V chargers due poor charge termination logic.
For an overnight charge, make sure the charger is capable of 4 amps or greater output. Little battery maintainers can take several days to fully charge a 12V battery and will not be of any use if the battery dies due to the limited output.
jfc6468
Waconia, MN
2022 Mach-E Premium, 2022 Subaru Ascent Touring
From daily review of this forum, it is clear that the health of your 12v battery is a primary concern of Mach-E owners. This thread starts with an owner who just had a new 12v battery installed and they are asking for recommendations on a 12v battery charger.
Do most owners charge their 12v batteries every night?
If they charge their car every night, yes since 12V is active during HVB charging. Attaching a 12V charger is not necessary for everyday use.
saj65
saj65
Bloomington, IN
2022 Mustang Mach-E
For clarification, I bought a replacement battery in October 2024 that was built in July -- it's been sitting in the garage ever since. I want to fully charge it when I bring it to the dealer to install at my 20K service. As always, appreciate the responses.
saj65
saj65
Bloomington, IN
2022 Mustang Mach-E
I picked up Clore Automotive PL2310 which has charge rate of 2, 6, or 10A. I assume 6A is the best choice for my situation? thank you
