Teslaeata
Nottingham, England, UK
Red June ā€˜21 RWD ER Premium MME
That would be great if reliable, but this issue has left enough people stranded that it appears to be somewhat spotty whether or not you'll get the warning in time.
šŸ¤·šŸ¼ā€ā™‚ļø
Can only speak as I find.
You never fully know what people are doing to make this unreliable and you only have their edited accounts of what they want you to believe happened.
Am happy to rely on a car that nobody messes about with in terms of battery management, external charging, ā€œconditioningā€ etc.
I’ve no appetite to just change components because they ā€œmightā€ fail with no evidence failure is likely at a notional service interval or at all.
I occasionally test the LVB and if it’s fine then it lives to fight another day.
In the same way I was wrestling in my mind with whether the transmission whine I thought developed since new was really developing or I was just imagining it worsening; had the transmission oil analysed several times over last 30,000 miles before & after an oil change finding the lack of evidence of particulate wear or any other tangible symptoms of wear or impending failure put my mind at rest the transmission won’t be letting me down anytime soon so won’t need to be putting in place transmission servicing, repairs or replacement for the foreseeable.
If it ain’t broke, don’t fix or f**k about with it is my guiding principle.
šŸ¤·šŸ¼ā€ā™‚ļø
You do a lot of driving, so your LVB is naturally healthier. When the car sits, and the LVB is used to keep some systems alive, it drains. And that can be hard on the LVB.
People who let their MME sit for days might not get the LVB maintenance yours gets. The problem is when it fails, it could fail at the worst time. It seems like changing it every three years is reasonable, even if it isn't necessary. It reduces the chances of getting stranded.
Whose recommendation?
I think this recommendation has been repeated multiple times in this forum. It is a recommendation I still think is valid, unless you are driving a crap ton. Like you do!
It is so easy to replace the LVB. It takes less than an hour. It is easy, and decreases the chances you might get stranded. Why not do it?
Teslaeata
We’ll see how LVB behaves now I retired and don’t drive so much at all.
Rk808
Neil
Mirai: Volvo XC60; MME
Excellent and great insights: Would still replace the battery at 36 months just because…
