12V BATTERY REPLACEMENT
Oldlawman
Essex UK
"Rosie" - Rapid Red Mach E AWD EXTD
Successfully replaced the 12v battery on my 22 plate AWD Ext Mach today with one supplied by Ford. Kept the battery on a trickle charger until installation. Charger indicated that the battery was fully charged. I followed the procedure for resetting the BMS as shown in an article on this forum but no matter how many times I performed the procedure the car's battery icon did not flash 3 times indicating a reset. Any comments please. I ensured that I flashed the high beams 5x and the brakes pedal 3x within the required 10 secs with the accessories button on.
RolyMach
Paul
England
2023 Mach E Select Long Range - Space White
I read in one article that when you first turn on the ignition after the 12v battery change you have to press the “OK “button on the steering wheel that comes up then carry out the standard procedure with headlight and brake pedal.
My car is nearly 3 years old and I’m thinking of changing the 12v battery, where did you get your new battery and what was the cost please
Hope this info helps
FordFamily
2022 Mach-e Premium ER 4X
I, too, have been reading the chain discussion about the 12V LVB replacement at three years. I had no trouble, but took the strong recommendation to replace at 3 years to heart. I also have a 22 Premium Extended eAWD. But that's not something I wanted to tackle. I scheduled a home visit by the local dealer. The team with a truck of parts, a mechanic and a computer guy, came to my garage. The same pair had been to my garage previously to address the door-locking software update. I didn't take it on warranty, but paid $235. I am glad I did it, I can rest more easily...for another three years.
Oldlawman
Oldlawman
Essex UK
Hi Paul - Spot on mate - many thanks. I pressed the OK button first as you said - then completed the procedure and the battery icon blinked 3 times so all done. Battery supplied by Allen Ford, Dunton, Essex cost £194.92 part no: F2641060.
RolyMach
Paul
England
I googled the part number F2641060 for the 12 v battery but nothing came up. Is there another part number .?
PWR
phil
mn
2021 mach e 4x, 2012 Thunderbird
Just replaced mine after 4 1/2 years. $133 from Ford. Followed instructions in YouTube video that only required removing two panels and was able to lift battery out and replace in about 20 minutes. Reset as described here works.
Zero reason to buy one from Ford vs Rock Auto if you are doing it yourself, unless you like to spend more money needlessly.
PWR
phil
mn
Much less hassle to buy from dealer. What was RockAuto cost?
flyingdutchman
2021 Mach E Premium
Lets not forget around $13 to ship and probably $12 in tax. Through Ford you can get points and credit for the $18 core return.
RockAuto price jumped over the New Year... $16 more.
