Mathington
- Jul 6, 2021
- Canada
- Mach-E Premium SR AWD
Until recently, I never thought about this but one very factor that should be considered for both 400v and 800v architectures is the amperage that the charger can deliver. @OutofSpecKyle recently mentioned in on of his videos or the InsideEVs podcast that there are 150kW and 350kW chargers that supply limited amps but really high volts. So if the car can't take advantage of the higher wattage, they will charge slower than a 350kW charger that could support higher amps (400+) then neither car would charge at their highest rate.
It had never occurred to me to check the amperage rating on the charger before as I always assumed it would max out based on whatever the kW the charger was. This could explain why I saw some less than favorable charging rates on 150kW and 350kW chargers despite my battery temperature warm enough.
