Benny’66
- May 13, 2021
- NY
- 1966 Mustang, 2021 Mach E GTPE
- Plant Manager
My wife “allowed” me to install the exterior EVSE on the side of the driveway as long as it was hidden in the landscaping and looked “professionally” installed. It gives me a ton of flexibility because my garage already has a 50 amp welding plug so I could use the “mobile charger” in the rare instance I parked in the garage. Since I live in a development, I don’t have to worry about someone stealing my electrons parked in my driveway.Hey there. I've owned my GT since October but I'm just getting around to looking more deeply into charging and really have only just started to use public charging. I have a few questions below.
1) I have a NEMA 14-50 240V plug on a GFI-protected 50 AMP circuit in my garage dedicated to my Mach-E. Would there be any benefit, at all, to spending money on a charging station (the ford one or Chargepoint, or whatever). It seems like these products are mostly aimed at vehicles that don't come with level 2 chargers, and the Ford mobile charger with the above setup I listed should be equivilent.
2) Is there any way I can easily test how many amps and any other relevant stats for what the car is drawing? Besides looking in the app at the expected time of charge completion. Or will this require special equipment to test?
3) I wasn't aware of the Plug-And-Charge setting until this week. Will this setting make it so I don't have to download the proprietary app for every charging network and set it up when I first park? For example, last week I went to a "Volta" charger for the first time and spent a good 10 minutes screwing with their app before I could walk away.
4) Is the above procedure also a replacement for having to find a charger in the Fordpass app and activating that way?
5) Has anyone set up a charger on the exterior of their home (versus how I have it in my garage near the plug and panel)? Pros/Cons? How easy was it?
6) Do people find they have to back in to most public charging stations as they were positioned for vehicles (like Tesla) with the charger in the back and will not reach to our charging port in front of the driver's door?
The install was rather easy. I used rigid conduit so I only needed to go 6” deep and the distance to the house was only 12’. Panel box was on the same wall in the basement so it was easy to pull the #6 wires and #8 ground. I just used a metal mailbox post from Lowes. Ran Sealtite inside the post from the rigid up to the elbow. Switched to pvc when I entered the basement over to the panel box. And I was able to use a 60 amp breaker so the chargepoint is set at 50amp (MachE can only use 48 of it). There have been some Friday nights getting home from work that I can get a few extra miles in her before going cruising.
