Align cruise control with the speed limit.
mu5e
Seattle
None
Seems like MME is aware of the speed limit on the highway ( I see it on the dash). So seems natural to have the option to set the cruise control to follow the speed limit (or within 10%). Is there an option for that?
geftsnowball
Washington
'22 Mach-E, Grabber Blue, Premium AWD ER
Yep, but be warned, it can incorrectly detect a speed sign, e.g., a side road, or a few other scenarios. This can cause you to rapidly speed up or slow down without warning. At least, that's what it sounds like from reading others' experience with it. I've set mine to off just because I like to explicitly control my speed.
Ford Mustang Mach-E Align cruise control with the speed limit. 1676446954543
mu5e
mu5e
Seattle
None
So what on page 232, seems like they explain how to enable it :)
Can you give me the link to the document?
geftsnowball
Washington
Sure, here: https://www.fordservicecontent.com/...-Owners-Manual_version-1_om_EN-US_10_2021.pdf
I searched for "mach e manual" and clicked the first link just to get the description because I knew it was there but didn't remember the specifics. Depending on your Sync version it may or may not be accurate. You might be able to find the latest updated digital manual via one of the options in the car (read comments about it... and it missing after the 4.1.2 update... but have never personally looked myself).
The manual is also available in FordPass.
elmedico27
Drew
Missouri
2022 Mach-E Premium AWD ER
Exact reason I turned it off, soon after it “saw” a 5 mph sign while I was on the highway. I still see discrepancies between what the car “sees” and what Apple Maps has programmed in all the time.
byoungblood
Bart
Berryville, VA
2012 F150, 2007 Mazda 3, 1999 Jeep Wrangler
I had it on for the first 2-3 weeks that I owned the car, and then turned it off.
On some roads where it has no speed limit info, it defaults to 25 mph. You will pass a speed limit sign, which it will recognize, and it will set the cruise to that speed plus/minus your tolerance. Then, without any warning, it decides the limit on the road is 25 mph again and slams on the brakes to slow the car.
Tooling around at 60, it picks up a speed sign on an adjacent ramp, quite a distance from the travel lane you're in. It again rapidly decelerates down to the "new" speed limit. I encountered this 2-3 times on my drive home from work. Took looking at Google street view to spot the errant sign.
An improvement would be to require the driver to press OK or provide some other feedback if the limit (either detected by the camera, or whatever is in the internal database) varies more than 10 mph from the previously detected limit.
Kabish
2021 Mach-E Mustang
100% would not recommend turning on.
I used it when I first got my car and it worked "okay" for a bit. Then it started to get real squirrely and I shut it off. I turned it back on months later and had it drop me from a 70mph highway to 20mph multiple times. I've also played around, expecting it not to work right, on a local freeway. I had it change my speed from 65 to 5 or 15mph multiple times for no real good reason. Think I might had posted a video of it somewhere here.
Don't use it unless you like getting rear ended, Ford should remove it from the car. Its a HUGE safety concern that they cover themselves by saying "The driver must always be ready to take control" BS...
Rory
Rory
Davis, California
Mustang Mach-E 2022 Premium ER AWD
I've had speed limit following cruise control on other cars I've rented. There are so many ways the car can be fooled that it's not practical. This is not just a Ford issue.
For example, speed signs on a road coming off your road, speed limit signs partly covered causing a misread, construction zones that have reduced speed limit signs but then just a resume usual speed sign instead of a numerical sign at the end of construction, etc.
mu5e
mu5e
Seattle
None
I'll give it a try. My friend with Tesla Y uses it all the time in our area, so maybe it is not that bad.
DevSecNetOps, General PITA
If the sign rec. is turned off does the speed limit sign still show up on the small display? That's all I need.
geftsnowball
Washington
Yes, you can turn everything on -except- the "intelligent" speed sign recognition speed adjustments if you want, e.g., I have everything on except that and I can see the detected speed on the dash and even have the speed limit threshold warning (speed sign image just blinks if you exceed what it thinks the limit is).
Skip Towne
New Hampshire
Mach-E 4x Premium
Wait, what????
You are supposed to pay attention to speed limit signs on the highway? Are you sure about that?
That seems like inviting a rear-end crash where I come from.
Auto Motive
Doug
Valencia Pa
I find it is a great tool and use it all the time. Gives my arthritic foot and ankle a rest. Only time it slowed down was reading the 25 mph road parallel to the road we were on at 45 mph. Great on the turnpike using 5 car length ad captive cruise at 70 mph, slows down and speeds up every time.
Wait, what????
Forum needs a "That part" emoji.
