Android Auto Navigation Issue
Dnorwood98
D
WA
Education/Healthcare
So I noticed this weekend that if I used Android Auto to navigate, directions would go to the driver display but the destination distance always read 0. Anyone else seeing this? Tried doing a search, but wasn't successful at finding anyone reporting this.
hack-e
Austin, TX
2022 Prem AWD ER MME
Robotics Engineer
I haven't seen that. Very strange.
hbirring01
Baltimore, MD
2021 Ford Mustang Mach-E, 2025 Rivian R1s, 2021 Tesla Model 3
what power up are you on? Did you do a sync reboot by holding volume down and track skip until the center screen reboots?
ack154
2023 Mach-E GT PE
Which map app are you using? Google Maps? Waze? I've used both and have not seen that. I have had some strange characters show up on the driver's display for the current road/highway - but that's the Ford system trying to read whatever the data in Waze/Maps says for the street name or road.
Dnorwood98
Dnorwood98
D
WA
Waze, I will try a sync reset to see if that changes the behavior.
Dnorwood98
Dnorwood98
D
WA
Looks like it was some kind of bug on Android Auto's end. Once I switched over to Google Maps, the bug went away for Waze as well.
Dnorwood98
Dnorwood98
D
WA
Bug is still reproducible, only way to get the IPC to show the destination mileage is to start navigation with Google Maps, then switch to WAZE.
Dnorwood98
Dnorwood98
D
WA
Just another update, Waze is still not pushing destination mileage to the center console. Shows destination is 0 miles away. Has anyone been able to reproduce this? Google Maps is fine, but Waze, which I usually use, is not pushing information. Not sure if it is a Waze or Android Auto issue. But it is annoying.
MrFord
Etienne
Montreal, QC
2023 Mustang Mach-E
Same here, '23 Premium. Distance only started showing in the IPC recently after an update. Google Maps shows the correct distance (like with the Ford Navigation), Waze shows 0. That's on Android Auto in my case (haven't noticed on CarPlay).
I have had the same behavior in my '21 Edge with Sync 4, where the navigation screen in the IPC will show 0 when Waze is the navigation app, but will show the correct distance with Google Maps. It's been like that since we got it new, so I assumed it's a simple bug/limitation with Waze not sharing the correct data back to the car.
ack154
2023 Mach-E GT PE
Same today. I just got the 10.1.0 update and tested both. Google Maps now shows correct miles to destination on the IPC and shows estimated charge on arrival on the maps screen.
Waze was still showing 0 miles to destination on the IPC.
YeOldeTraveller
Clark
Ann Arbor, MI, USA
2024 MME Rally
I was getting the zero miles to destination in the driver display, but that was when using ABRP through AA.
I'll check again once I get the update that allows battery integration.
Jacnoc
Allen
Chicago suburbs
2025 Mach-E Premium Ext Rng
Well this may be an older thread, but this problem started happening today. Google maps through Android auto in my 2025 Premium will only show 0.0 miles to destination on the driver's panel. It does show turn by turn directions. The miles remaining does show on the main/big screen.
The Ford navigation does show proper miles remaining on both screens, but I'm not willing to use that app. I did reboot the infotainment system, which didn't help.
Suggestions? It's so odd this suddenly broke!
cheerioboy26
Matt
Pennsylvania
2023 Mach-E Premium AWD Ext.
It's happening to a lot of people, and the opinion is that it was a bad Google Maps update. Mine was broken and has now returned to normal, so I guess I got an app update.
Naren
Naren
Albany NY
Mach E Premium EX AWD, RIVIAN R1S
What is your google maps version ?, mine updated yesterday and now its showing 0 miles
