Mike G
- Mike
- Mar 27, 2022
- N. AL, USA
- '23(J1) Mach-E GT-PE, '22 F-150 Lightning, '24 Bronco HLE 2Dr
@Jessnyc
The next time you intend to drive the car do a Battery Management System reset prior to departing.
Press the start button without depressing the brake pedal so you're in accessory mode.
Using the left hand turn signal stalk flash the high beams 5 times, and then depress the brake pedal 3 times and observe the red battery icon on the instrument cluster cycling 3 times. Press the start button to turn the car back off. And then Start the car as normal and drive.
See if that helps.
See if that helps.
