Beosonic
Aulander
Italy
Mustang Mach-E Premium AWD
Hi I did on MME 21 both changes and it popped up in sound setting with dot working but every power cycle I have to go in sound to enable profile. Any solution for that.
I did it too on my MME MY21 and I don't have to re-enable profile every power cycle, but I still have SYNC v. 23291. Try a SYNC soft reset maybe it solves the issue.
Mach e Aankh
NJ
Mach e Ex RWD BLK
Self
Thanks will try that. Just one more thing did you change it 8 or 9 in DSP
Aulander
Italy
I did this:
783-01-01 xxXx xx - Add 1 to X in DSP
then I enabled Beosonic Menu in the APIM options, not in the 7D0-01-01 as-built parameters.
Mach e Aankh
NJ
Mach e Ex RWD BLK
Self
I did this:
Thanks tried both rebooting couple times and APIM options like you and its there but same problem like before and no sound difference. Maybe be I'm doing it wrong or not changing right lines. I really like to get it working.
Thanks again
rugedraw
Javier
Miami, FL
Auto Sales
Thanks again
Your car is not on the latest DSP software. That may have something to do with it.
DeusEx
New York
2023.5 Mach-E Premium ER AWD
One of the BluePilot developers with a MachE is who discovered it. It should work for anyone with B&O here.
Code:
<del>783-01-01 xxXx xx - Add 1 to X
7D0-01-01 xxxX xxxx xx - Add 8 to X
So I was a bit confused by this as it said to "add" 1 and "add" 8, and I literally added whatever number I had plus the original values. Needless to say, the APIM modification didn't work quite right for me.
What made sense for me was:
DSP
783-01-01 yyXy yy - Replace X with 1
APIM
7D0-01-01 yyyX yyyy yy - Replace X with 8
In case anyone is wondering, my original values on my 2023.5 Mach-E Premium were:
DSP
783-0101 F501 8002
APIM
7D0-01-01 A081 0802 BCC0
New values were:
DSP
783-0101 F511 8002
APIM
7D0-01-01 A088 0802 BCC0
**See this: https://www.macheforum.com/site/threads/how-to-enable-b-o-beosonic-with-forscan.39142/
Snakebitten
Coastal Texas
2023.5 Mach-E
DSP
APIM
In case anyone is wondering, my default values on my 2023.5 Mach-E Premium were:
DSP
783-0101 F501 8002
APIM
So
F511
And
A088
Didn't work?
I'm going off memory, but that sounds very familiar to what I had and did.
DeusEx
New York
Sorry those values worked. I was distracted and forgot to include the values I ended up using. You are correct and I updated my post for clarity.
What I did was add 0+1=1 for DSP and 1+8=9 for APIM. I took the word "add" too literal.
DSP
APIM
DSP
783-0101 F501 8002
APIM
New values were:
DSP
783-0101 F511 8002
APIM
**Updated for clarity**
+8 for the APIM is the correct operation. So if it's a 1 before, it will be a 9 afterwards. If you do 8, your radio presets will disappear. I had to change mine to 9.
DeusEx
New York
Good to know. I will have to check my radio when I get in the car this morning. When I had the APIM value at 9 the option for Sound wasn't selectable to access Beosonic.
DeusEx
New York
Yup, missing the radio presets but can still switch the different channels by pressing the squares on the screen or on my steering wheel. I'll be changing the settings later and trying to figure out why I couldn't press sound when 9 was set.
