Best Mach E Rendering?
Whatstreet
Fremont, CA
Chevrolet Volt, Ford Expedition
Electronics Engineer
A few words about range.
If you are driving long distance you will need to use level 3 DC fast charge. It charges fast while the battery is less than 80% then it slows down a lot so that's when you stop charging. 80% of 300 miles gives us 240 miles of range in this situation.
Now lets say its cold outside and you have the heater on, its uphill and against the wind. All worst case but it could happen. Miles per kWh will be reduced by maybe another 20%. Now the range with all these less than optimal conditions is maybe 180 miles.
I can probably make it to another charger along the way with 180 miles of range so that's one reason I want 300 miles of range in optimal conditions.
It is correct that you can draw more current from a bigger battery. The current from each cell is the same but it has more cells. Dual motors are thirsty when gunned. That's why the dual motor AWD cars have bigger battery packs.
Higher voltage is more efficient. The current will be lower for the same wattage, reducing losses. I have not heard what battery voltage Ford will use. Porsche is developing 800V battery packs and drive systems.
MachSpeed
Doc
West By God Virginia
2019 Ranger XLT 4x4 SuperCrew 2015 Mustang EcoBoost convertible
Very good explanation thank you.
MachSpeed
Doc
stmache
Scott
Leesburg, FL
www.sthomasphotos.com
2023 Ford Mustang Mach-e GTP
Photographer
MachSpeed
Doc
I don't know...that's a lot of surfaces air can catch. I suspect a much more aerodynamic front end as EV's don't need air for cooling an engine.
That's thankfully just a terrible photoshop the real Mach E won't look anything like that.
ToadStool
PNW
Ford Mach E GT
What does everyone think of this Mach E rendering? Too much Mustang influence or just right?
I have to admit it looks good but if I were a Mustang owner I might think that front end is too similar.
Ford Mustang Mach-E Best Mach E Rendering? 1654442173537
Ford Mustang Mach-E Best Mach E Rendering? 1654442079424
This are both quite nice. But I'd lean toward this white one with the wheels from the black one.
