Can't Hear Turn Signals (normal?)
jmatero
San Jose, CA
2022 MME GT-P
I'm unable to hear the turn signal "clicks" unless the car is stopped and parked somewhere quiet... like my driveway... it's that low. Underway it's imperceivable. Is this normal? Haven't found a setting to increase the volume.
Yeah I agree the volume level of the cluster alerts is too quiet to hear at highway speeds. The speed compensated volume of the radio leaves a lot to be desired as well. Guessing they didn't really test the auto levels on a track, just on the bench. It would be nice if they could add a speed compensated volume for the cluster alerts.
Wonder if this is a problem with 2022 only?
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
'21 chiming in (pun intended...). It's very soft, however, I noticed if you let it go, you'll get the Mach E Bong Bong Bong.
I kept looking for why it was bonging me, then I realized the blinkers were still on. Clicked them off/bong went off.
So at least you won't be driving 100 miles before you find out you've been trying to make a left turn the whole way...
Jimbo
Jimbo
US
Premium 4X
I wish there was a setting.
Personally, I've always (in previous cars) relied on the relay cue. I was hoping I'd get used to the Mach E cue being a quiet talker, but here I am six months later still having to look down to determine if I remembered to turn them off or not.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
To increase the turn click volume, turn blinker left for 2 clicks, then right for 2 clicks. Continue doing this and you’ll notice that the clicks become louder each time you repeat this.
I don’t think it’s in the manual but it’s a Ford thing.
Jesse Vos
Jesse
ROYAL oak MI
MOCH 3
Teaching
I just wish there was a alert that the blinker is on after 30 seconds or so. Is an alert like this available in the settings menu??
Never knew that. Will give it a try. ?
PilotMark
2022 Mach E Extended, Mini Moke, FRS, Prius, FJR, 1966 Shelby Mustang
Interesting piece of information.
How do you make it quiet again?
LNFitz
Denver
Ford Mustang Mach-e
Saddle Fitter…and yes, have worked with Mustangs
Not just 2022. Kind of like the quieter signal (until I don’t turn it off) but dont really like that the audio volume doesn’t moderate as much as it should.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
It probably goes back to quiet after it gets past the loudest. I never tried that.
The attached says do right, then left. Doubt if it makes a difference.
Ford Mustang Mach-E Can't Hear Turn Signals (normal?) 7B088694-B4A8-43D3-B104-35C7A205A422
PilotMark
Good to know I did not find it in the 2022 owners manual.
I'll probably set it once and forget it forever. Then I'll have the fun of discovering it again.
