Shayne
- Aug 9, 2020
- Northern Ontario Canada
- 2021 MME4x Prem
- Retired
I have added this home location now 3 times with the same result, does not work. Every time the coordinates, the fordpass app and the sync OS all come up with different locations.It saves a charging location even from just a momentary charge, so it doesn't take many miles. I only did a 2-minute charge to get it to re-record my home location in the system so I could then tie a schedule to it.
Sounds like you've already done ample testing though. If the dealer repeated the problem (charged it at the dealsership and it saved as a spot 100's of yards away), they should have all the proof they need. Kinda sounds like there's 2 different GPS units in there and one of them is miscalibrated.
So much revolves around this very simple task that after a month and a half of ownership it is starting to be a PITA. How long have we heard that an OTA is coming soon to fix all our problems. My service guy said it will go back in for the fix. For me it makes no sense to add complexity to a problem that can cause further problems at this early stage so a hardwired upgrade made sense. That is if software can fix it?
