Car set to charge upon plug in??
Byrus
2024 Mach E Premium
Hi. So I have a desired time to charge, between 2 and 4 am. However, the app still says it will charge when I plug the car in, and it does? Why does it do that? How can I change it?
So once it starts immediately charging I then go into the app and stop the charging. Will it then start again at 2 am?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
I’m assuming you have setup a charge location?
Post a screenshot of the charging setup page from the Ford app
Byrus
2024 Mach E Premium
Just did it. Thanks.
2 hours is totally inadequate. Car will start charging immediately because of that.
Byrus
2024 Mach E Premium
Ah, you think that's why it said will charge upon plug in? Will it now start charging at the time I set (or earlier if it need to)? I really don't care if it gets to 50% but I need more than what it has. I wish I could see it to charge for less than 50%.
Thanks.
240V will start immediately if it cannot hit the target.
120V will always start immediately.
AliRafiee
Ali
Seattle WA
Software Eng.
9% to 50% needs more than 2 hours. If you have a departure time, it will start charging to make sure it reaches 50% by your departure time.
I would assume that if you don’t have a departure time it would start charging at 2am. But not sure.
Byrus
2024 Mach E Premium
Thanks all.
Byrus
2024 Mach E Premium
So I just plugged it in and now the app says it's waiting to charge but it's actually charging. I have the universal Tesla charger and the green light indicates it's charging as does the Tesla app. Currently have 39% charge, it's set to max 50% charge and to charge between midnight and 4 am.
Any thoughts?? Ugh!
I unplugged it and plugged it back in but the same thing is happening. It shouldn't be charging.
UPDATE: ok it finally stopped. Not sure why it took 10 minutes to stop.
E90alex
Seattle, WA
‘25 MME GT
It’s probably pulling a small amount of power for other stuff. How much power did the charger say it was pulling?
If you want a hard limit to the charge window then set it in the charger and not the car.
Byrus
2024 Mach E Premium
Maybe that was it. The Tesla app doesn't show any charge history for that time.
Thanks
