Charging port light no longer indicates charge
Hollygangle
Holly
Bellingham
Mustang Mach E
I charged last night and this morning when I went to unplug the charger, the charging light did not turn on to indicate the level of charge. This afternoon I plugged it back in to charge and the light, which usually pulses when charging, did not turn on. It seems to be charging fine, however. Also, what does the button in the center of the lights do?
Ford Mustang Mach-E Charging port light no longer indicates charge PXL_20220530_215742483
Ford Mustang Mach-E Charging port light no longer indicates charge PXL_20220530_215747070
Might you have inadvertently turned it off through the menu in the center screen? The center button is for stopping the charge at a DCFC station.
fpasta
Check on your Sync screen. This happen to me on my first charge. I thought cool charge port light is cool. Then the second time charging the it wasn't on. Checked the sync screen the charge port light toggle was off.
SpaceEVDriver
Ground-based: CA Route 1 AWD, ER
Planetary Science
The button is for stopping a DCFC charge and disengaging the lock. Page 173 from the 2022 manual.
Ford Mustang Mach-E Charging port light no longer indicates charge Screen Shot 2022-05-30 at 16.55.05
Hollygangle
Hollygangle
Holly
Bellingham
Mustang Mach E
I'm not finding a charge port light toggle. Do you remember where you found it?
fpasta
Go to the sync screen and go to Settings. There's a Charge Icon button. You may have to slide the screen up to see more icons. You press that that and should see the charge port light toggle.
Crilly
Dale
Hartland, Wi
Reset your charger.
Hollygangle
Hollygangle
Holly
Bellingham
Mustang Mach E
Yes, I see the Charge icon button, but there is no charge port light toggle that I can see. Sorry, I'm going to need visual aids, I guess. I've been all over the menu and not found any charge port light toggle.
GuliblGuy
Justin
North Tustin, CA
Shadow Black 2021 Premium 4X Mach E
JAM
Mustang Mach E
The latest software update makes a major change on the UI and the charge port light setting switch is no longer available, that I can find.
dj_stang
{None}
2022 MME Premium -> 2023 GTPE
I can’t find it either. I wonder why they removed it. Too many people hogging up free chargers?
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
I was reading through the manual and other posts, trying to find out how to turn off the blue "Charge" indicator lights. The charger/unlock icon is greyed out on the controls page. It looks like you are not able to turn off the ring of blue charge lights, at the charge port door anymore?
Ford Mustang Mach-E Charging port light no longer indicates charge IMG_1072
