agoldman
- Jan 23, 2020
- Charleston, SC
- 2024 Mach E GT vapor blue- perf pack-alloy wheels
Have we seen these kinds of failures in more mature markets like Europe? Mode of failure seems a bit different and it's a different charge provider, although these are rare isolated cases, something is going on that these were not prevented by an issue being detected and followed with a successful call for termination by the charger and/or car.
I had thought about drilling holes for the battery jump points and the disconnect, but then I ended up taking the whole cover off a month ago and it came off much easier than I expected (after the dealer had done it for the first time the day before). It comes off easily enough that I'm not gonna bother drilling holes. Basically just have to pull hard at each of the clip points (which quickly become apparent where they are as you work your way around both panels).Please say more or direct me to the topic on the MME Forum where I can learn more about drilling the holes. I did see a YouTube about the drilling of holes through the frunk cover to access the 12V battery connectors. I want more info, like: what diameter hole cutter, where to get covers, etc. Thx!
I drilled mine for easy access to the LVB jump points. The rest was just too much to do. And the covers really aren't that hard to get off.I had thought about drilling holes for the battery jump points and the disconnect, but then I ended up taking the whole cover off a month ago and it came off much easier than I expected (after the dealer had done it for the first time the day before). It comes off easily enough that I'm not gonna bother drilling holes. Basically just have to pull hard at each of the clip points (which quickly become apparent where they are as you work your way around both panels).
The disconnect would be tough to use through a hole anyway. It's a little tricky to figure out, even with the panel totally off. Have to get to the lower side of it.
Before anyone decides to drill any holes, I'd try taking the panels off/on a few times. They tend to loosen up after the first removal.
The pins start falling off the underside of the panels and are hard to control/find. It is a lot easier to just pop a couple of 2" plugs for access than ripping those two panels off. Wonder if the 2023's are coming with factory access plugs? It make sense since every time service hooks the FDRS up to it it seems they need to connect a mega amp 12V charger. Glad I did it and no one sees it.I drilled mine for easy access to the LVB jump points. The rest was just too much to do. And the covers really aren't that hard to get off.
We'll find out ... Soon™.Wonder if the 2023's are coming with factory access plugs?
Was wondering with your carplay prob are you on iOS 16? I am still on 15.7.1 so was thinking that maybe is why mine is still working great. Wondering if the problem may be connected to apple 16 and could be fixed that way?We'll find out ... Soon™.
My car has achieved sentience and has a warped sense of humor. Since the car was put in advanced analytics, Carplay has mostly behaved itself. Hands-on BlueCruise is another story though.Was wondering with your carplay prob are you on iOS 16? I am still on 15.7.1 so was thinking that maybe is why mine is still working great. Wondering if the problem may be connected to apple 16 and could be fixed that way?
I drilled mine because:I drilled mine for easy access to the LVB jump points. The rest was just too much to do. And the covers really aren't that hard to get off.
We throw around the 90% number a lot (roughly 90% of charges being on L1/L2, usually at home, and maybe 10% on DCFC). Don't know how accurate of an estimate that is, but it's probably in the ballpark for the overall average.I’m fortunate that I only charge at home other than 1 time on a 400 mile long trip. How many people charge on the road?
Interesting, I mentioned your situation in this topic this topic the other day:Here we are nearly 4 months since this happened and Ford has finally reached out to me. They seem to have concluded that the problem was in fact with the vehicle because they offered to reimburse me the $1000 deductible from my insurance.
However as I don't have a receipt for the repair, since I sold the vehicle to the dealer who did the repair and they took the $1000 off of the initial offer to cover the repair, the absolute knucklehead of a Ford Rep once again is refusing to compensate me.
My proof would be a picture of a check for $57,000, a bill of sale for $56,000, and the dealer explaining to Ford Corporate that the difference is the $1000 that went to the repair.Interesting, I mentioned your situation in this topic this topic the other day:
https://www.macheforum.com/site/threads/car-driver-article-on-ea-charging-failures.26654/
Perhaps you could just submit proof of the $1000 deductible payment you made?
