Dead Car Thanks to Cold Temps Causing HVB Module Errors
mtbikemj
MJ
Carmel, IN
2022 Mach-e GT PE Dark Matter Gray
Do you know if it is an Absorbent Glass Mat (AGM) 12vt battery?
Rabidsquirrel22
Rabidsquirrel22
Ben
North Carolina
2016 Camaro SS, 2021 GTPE
Well I finally got the call and picked up the car today! I’ve only driven it about 4 miles but so far everything seems to be fine. Here’s the final repair documentation
Ford Mustang Mach-E Dead Car Thanks to Cold Temps Causing HVB Module Errors 9F86D560-90B7-4387-A27C-7910B9AE3043
Now the bad news…. I discovered a gash in the rear bumper right over the reverse light. So it looks like someone backed into something and nicked it. Luckily I did a walk around inspection at the dealer and caught it there. I have to go back on Monday since the manager was already gone for the day.
So the saga has not ended yet!
Ford Mustang Mach-E Dead Car Thanks to Cold Temps Causing HVB Module Errors E207825A-333F-44C3-8653-9F4EFB4AE770
Caliroute1
Scott
Wesley Chapel,FL
2021 Mach E GT
Operations Manager
Well well well. Another HVB issue. Only my second one in less than three months You have some catching up to do
Ford Mustang Mach-E Dead Car Thanks to Cold Temps Causing HVB Module Errors F5A6F87B-74AF-4064-8F60-C28F08D51CE0
Rabidsquirrel22
Rabidsquirrel22
Ben
North Carolina
I sure hope not lol. It seems like we didn’t have quite the same issue, so I’m hopeful my fix is more permanent.
Good thing is, that is an easy fix!
Thanks for sharing your HVB issue/experience and all the details. If this ever happens to me, I will be able to "help" my dealer go down the right path to get it fixed.
