- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
I would NOT recommend changing chemistry of the LVB as the charge controller is likely hardcoded charge curve to match the oem battery. Especially not changing to Lithium in unheated Frunk since Li batteries should NOT be charged below 32F/0Cget one of these and when you get back put back the original
https://dakotalithium.com/product/dakota-lithium-12v-100ah-deep-cyle-lifepo4-marine-solar-battery/
At least you wont miss your trip.
I WOULD recommend a frunkectomy and wrapping the LVB in a 12v Electric blanket wired directly to the LVB. As I put in a separate thread, I suspect the HV to LV charge controller has temp sensor on or near the LVB which is used to compensate for voltage drop in cold, and the programming is not allowing the HV to bump charge the LVB when it *should*.
$20 - https://www.amazon.com/Electric-Blanket-Tailgating-Emergency-Stalwart-BLUE/dp/B001QJQ22O/ref=sr_1_3
