Did your Mach-E come with a tow eyelet?
Did your Mach-E come with a towing eyelet?
  • Yes
  • No
Results are only viewable after voting.
Bukaye71
Scott
Walnut Creek, CA
2021 Ford Mach-E FE RR
It appears that there’s supposed to be a tow eyelet included with the Mach-E. I discovered under the inflation kit a cut out with the shape of one. I also see an access panel on the front bumper area. There’s no mention of it in the owners manual.
Did your Mach-E come with one?
Ford Mustang Mach-E Did your Mach-E come with a tow eyelet? 26A33D43-5FDF-4E8B-8C8A-766D6748CAE0
Ford Mustang Mach-E Did your Mach-E come with a tow eyelet? F7B81C4A-B7DA-4F77-9B7F-F7EFDEDD7CDE
Ford Mustang Mach-E Did your Mach-E come with a tow eyelet? 12CF2BAF-C93B-4E9A-9C27-53B1F97FEED1
  • Like
Reactions: UW2
Bukaye71
Scott
Walnut Creek, CA
It appears that there’s supposed to be a tow eyelet including with the Mach-E. I discovered under the inflation kit a cut out with the shape of one. I also see an access panel on the front bumper area. There’s no mention of it in the owners manual.
Bukaye71
Scott
Walnut Creek, CA
If yours came with the tow eyelet what model did you purchase?
Where would you attach a towing eyelet? That access panel on the front bumper just houses the electrical leads to emergency open the frunk, no?
TxTom
Tom
Irving TX
2023 Mach-E GTPE and 2021 Escape PHEV Titanium
Where would you attach a towing eyelet? That compartment on the front bumper just houses the electrical leads to emergency open the frunk, no?
Mine car was just received this week...not one there even a spot for it. May be for the European cars? No where to attach it on my car anyway.
Bukaye71
Scott
Walnut Creek, CA
Found the part # for the missing tow eyelet /hook
Marcel
The Netherlands
Woodworker
Ford Mustang Mach-E Did your Mach-E come with a tow eyelet? 0A95CAC4-869D-4B2E-B284-5C6DED18B630
Front and rear towhook positions in our manual
sockmeister
Pennsylvania
2021 Mustang Mach-E4x
SW Engineer
That doesn't exist for us here in North America, unfortunately.
Yep. This is for certain European destined cars only. I believe there's a regulation requiring that the car have it.
Isn’t that where the emergency 12V battery jump cables are on NA cars?
