Dirty rear window
The tires kick up dust into the wake behind the car. Since that's a low pressure zone, the tire spray and dust gets trapped behind the car and can settle on the rear window.
Ford Mustang Mach-E Dirty rear window 20-Figure1.2-1
How dirty the back window gets is a function of how dirty your roads are. If you want to make the back glass easier to clean, put a ceramic coating on it and use the rear washer.
Makiato
Just bob
Anacortes Wa
2021 LR AWD
Travel Cargo, Guitar Storer, Architect
It's easy. Most people aren't bright enough to figure it out. It gets dirty from the airflow going over it and then bending back.
The following steps work well:
1) First, figure out where you are going.
2) Second, orient the rear two tires in the direction you are going, with the front tires aimed behind them.
3) Shift to D, say "HEY GOOGLE, CLEAN WINDOW", and then shift to R and drive.
Easy, peasy.
wow. thanks. bet you thot it was funny.
NY_Cade69
Cade
PA ON NY
Reddy Kilowatt, a 2025 Molten Magenta Premium Sport Package ER/AWD
Also applies to aircraft airfoil surfaces where the wings produce lift due to pressure differences above and below!
@Kamuelaflyer and I will attest to why heavy planes can fly without falling out of the sky !
And it's all possible due to the plane wanting to fall! 🤣
leemoknows
Indiana
2026 Mach-e Premium Extended
What I do on mine is after wash and drying, I'll put on Rain-X on all the windows. That way when it does rain it will tend to push off dust when you drive. I've done this on my last couple of cars and it's worked great. They have fancy ceramic blah-blah ones too, but rain-x works fine IMO.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
No, I just have an aerodynamics and fluid flow education. The phenomenon is similar to one that we find in an engine called "windage." That's one where the rotating mass creates a low pressure area immediately surrounding it, making all of the oil that is aerisolized want to stick to the rotating mass (which in turn creates massive drag on the rotating mass). This is countered in high-performance engines by the use of windage trays and crank scrapers. 🤔🐩
In short, because science.
AZBill
Rearview mirror cameras solve this issue, you never notice the dirt anymore.
NY_Cade69
Cade
PA ON NY
One drop...
It will need a wash/wipe mechanism, like the front cam doesn't have any more...
AZBill
One drop...
I have two vehicles with those cameras, and since they are built into the spoilers, they do not get dirty.
NY_Cade69
Cade
PA ON NY
And they both have wash systems...
AZBill
No, neither one. For example, I have two cameras mounted on the spoiler of my Hummer, one for the rear view mirror, the other for the truck bed, they never get dirty. The backup camera and the hitch camera, mouted on the tailgate, do get dirty. The only camera washers on my truck are for the underbody cameras, the front facing one gets really dirty when off roading and the camera screen has a wash icon on it for that.
My Cadillac has the rear view mirror camera on the spoiler at the top of the hatch and it does not get dirty. Only the backup and hitch cameras mounted lower get dirty. The airflow over the spoiler keeps the dirt from getting that high, the turbulence/suction is below the spoiler.
oljun
Ontario, Canada
2023 Ford Mach-e Select eAWD
Methinks there is a lot of "windage" throughout this entire thread! 😁
