Disable Mach-E Lane Centering?
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Hello,
Is it possible to remove the Lane-Centering so it doesn't activates by default when i start the vehicle?
Anton
Press the lane-centering button on the steering wheel. Once it's off, it stays off until you hit the button again to turn it on. The button is on the lower left hand side of the wheel and is labelled like this "/ \"
SashaLondon
Sasha
London
MME AWD SR
Is this true that it is a law in Europe?
hybrid2bev
2026 Rally
Hello,
Anton
Lane centering is only available in conjunction with cruise control. Actively steering to maintain the center.
Lane Keeping is controlled by the procedure @timbop described. Turn it off via the steering wheel control before you turn off the car and it will stay off. Lane Keeping just alerts you if you are drifting out of the lane and can gently nudge you back into the lane.
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Alright, so it’s not possible to switch it off completely?
Because even of I’ve had it off it switches on by default next time i start the car.
On US vehicles: vehicle - settings- driver assistance-cruise control. Under Intelligent Cruise Control switch lane centering off.
phidauex
Colorado
Renewable Energy Engineer
There are two places that lane centering can be turned on and off. One is in the Intelligent Cruise Control settings, which says whether Lane Centering should be used while in cruise control mode. You can still turn it on and off manually with the button on the steering wheel.
Ford Mustang Mach-E Disable Mach-E Lane Centering? 4E3ECF90-EC9B-44D1-9019-C8924A5EC567
The other is for the Lane Keeping mode which can nudge you back into the lane if you drift in normal driving. It can be set to Alert (buzzes the wheel but doesn’t apply steering) or Aid (which will actually apply the nudge), or both, and you can disable by setting to Alert and reducing the intensity to off. Lane Keeping settings apply all the time whether you are in cruise control or not.
Ford Mustang Mach-E Disable Mach-E Lane Centering? F9434983-408B-477B-B7FA-97376DEA4B31
As you can see I have the Lane Keeping set to Alert and Lane Centering set to On while in Intelligent Cruise Control. The settings do save so I get lane centering while cruise control is on, but not when it is off.
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Okay, Can you take a picture of your drivers display when it’s turned on?
Is it the same we’re talking about? It’s the icon of the car with two green lines on each side
Ford Mustang Mach-E Disable Mach-E Lane Centering? 4EA09C58-F9C8-4A46-8ADB-C2074D988C9C
hybrid2bev
2026 Rally
That's Lane Keeping mode. Click this button on your steering wheel to turn it off. Your image cut off the button.
(That's how it works on North American vehicles)
Ford Mustang Mach-E Disable Mach-E Lane Centering? Screenshot 2021-09-08 162527
Ford Mustang Mach-E Disable Mach-E Lane Centering? Screenshot 2021-09-08 163202
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Yes, I know.
But it’ll always come on by default everytime I start the vehicle. So it’s not possible to toggle it off completely?
hybrid2bev
2026 Rally
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Alright, so your screens doesn’t look like this all the time when you start it up?
With the speed to the right, car icon etc
Ford Mustang Mach-E Disable Mach-E Lane Centering? 939D1221-D2A7-4CA4-A8DC-F8F79B920CC3
Only if it was saved that way in the driver profile. For us, switching lane keep assist on or off is a profile setting that's persisted each time we turn it on or off.
FordMachET
Robert
Sweden, Gothenburg
Mach-E
Okay, but do you turn it off on the steering wheel or in Sync?
So this is your default screen then?
Ford Mustang Mach-E Disable Mach-E Lane Centering? C06B84DD-0D44-4844-8172-D2EDBEBB0E3B
