Driver ID -- log in screen only takes numbers?
Shayne
Shayne
Northern Ontario Canada
2021 MME4x Prem
Thanks. Other than cryptic update message in FP, there is no indication either in FP or the vehicle that I received an OTA prior the problem occurring. If they did push an update that broke communication between the vehicle and Ford cloud, I'm wondering whether they're going to be able to fix this problem with an OTA.
No indication it updated here either but they say yes. They noted we are in fleet mode which kind of make sense. Go into your conductivity settings and look at what you can not do. Not sure communication is broke but our cars may have been put in a different mode.
Usb C wired carplay working here now. App still locked at where it updated. Maybe they will wipe it out and install the new UI for us?
Johnny B
Chandler, AZ
2021 Mach E Premium RWD 2017Nissan Titan XD Diesel
Retired Software Developer
The only thing I cannot do under the Connectivity settings is turn on Wireless App Projection, whatever that is. Everything else appears to be turned on and settable, but I ain't gonna try to see if I can turn them off and leave well enough alone.o_O
With the exception of the new UI, I think I'd received all the OTA updates prior this problem occurring.
Thanks.
Yes, it's from an OTA. The OTA didn't finish correctly so you didn't get the notification about it. It's a BlueCruise map update for the gateway module (GWM).
Wireless app projection is what you need for wireless CarPlay.
Nothing to do with fordpass. Your car received an OTA that broke communication back to Ford completely. A fix is being worked on.
Hopefully. And hopefully, it doesn't require a trip to the dealer to unbreak communications. :p I'm having a field day finding things that have broken since the Friday early morning's OTA.
hawkeye3point1
NH
Is the issue hit or miss with this OTA, or does it happen to all?
Shayne
Shayne
2021 MME4x Prem
Thanks.
Ya just leave it nothing in there that is going to fix it. You should be able to configure it but seeing it will not will not help. I normally have the top few that feed data to Ford allowed to help at this stage but a lot are normally toggled off. You should be able to disconnect completely but now not allowed. Do you have the locked data for the insurance company on your conductivity?
How does bluecruise put us into a fleet?
Wired carplay working boots faster and no problems ;) Back to the basics.
What's wired? :p
Seriously, Wireless CarPlay worked fine on the past two trips in the MME. Roughly 170 miles between the two (two round trips to Kona). I'll take it. By comparison, we took the Raptor out to got to dinner last night. WTF? No wireless? How 2010s like. :p
Shayne
Shayne
2021 MME4x Prem
What's wired? :p
Really wired is still back to the future for me as my last vehicle was not connected and the radio sounded like crap. When you get spoiled at home that vehicle just stayed off. The mach-e sound is OK when fed a good stream which you can now control.
I don't think many people would get this OTA because the maps fix was rolled out previously in 3.5.2 or 3.5.3.3. BlueCruise maps would expire today if you didn't get a map update. So the issue is only with this particular update. Either way pretty sure this OTA has been paused for now.
It doesn't, the module it needs to update just also serves that role in fleet vehicles. It's a latent feature in the code that got turned on by mistake. It's a software bug so weird stuff can happen.
Shayne
Shayne
2021 MME4x Prem
For your reference this car updated to 3.5.3.3 a while back (oct 22, 2022)? Maybe not included in my package?
Have not seen a BCHF highway to date. Do not use BCHO much either. Where do I toggle those map updates off? Right now I am thinking do I really need them ;). Nothing caught fire here yet so it should be fixable. Thanks; it is good to have knowledgeable people here.
Johnny B
Chandler, AZ
Yep.
Pretty sure all these updates had been applied late October/early November
Cjpayne
Auburn, IN
21 Ford Mach E GT. 69 Mustang Convertible, 15 MKX
General Manager in manufacturing
I also can not turn wireless app projection on. If I update the GWM will that resolve the issue? My car was at the dealer all day yesterday for the recall update.
Xenotet
Zack
Central Florida
‘14 Ford Focus ST, ‘21 Toyota Venza Ltd
Chemical Engineer
I had this happen to me, too, about a week ago. Wireless CarPlay and Android Auto stopped working and I got this login screen pop up every time I started my car. Spent way too much time trying to get wireless app projection to work again. Any way to roll back an update or retry this one?
markboris
Sonora, CA
Add me to the list. Yesterday I got the Driver ID login screen also. Apparently has to do with fleet mode. Noticed that some F-150 owners have gotten this too. My Apple CarPlay does work wirelessly and nothing seems to be affected except the annoying Driver ID Login that pops up every time I start the car.
