- Jul 1, 2021
- SE MI
- 2022 Mach-E Premium 4X, 2022 Lightning Lariat ER
You're confusing terms.Makes sense. Is there any indication on either display that you are in a BC enabled area? Or do you have to turn on cruise control, lane keep assist, and lane centering, and then see if it works?
No, there is no map that exists that tells you that you are on a handsfree BlueCruise road. It was promised for May 2022...
You can turn on cruise (you already have the other options on), and have hands-on assisted driving, the car will stay between the lines, take turns, etc. You just keep your hands on the wheel and let it steer.
When you get on a divided highway that is handsfree, the instrument panel will tell you that you can remove your hands from the wheel. As you approach areas where you need to put your hands back on (i.e. big curve in the road), it will tell you.
