Larry Paul
- Larry
- Aug 27, 2021
- Southern California
- MME-GTPE, Sunbeam Tiger w1970 Boss302, 2002Rav4EV
I am interested to get a Ford Protect warranty as well... but I am not sure what the Ford extended warranty plan actually covers for our cars. https://www.lombardfordwarrantys.com are running a special through memorial day...but I am reading the fine print.
It does include:
Engine - Cylinder block and Internal Lubricated Parts, seals and gaskets, the cylinder heads, manifold (Exhaust, Intake and bolts), factory installed turbocharger/ supercharger units, timing chain (gears or belt), flywheel, valve covers, oil pan, timing chain cover, oil pump, water pump, thermostat, thermostat housing. Also flywheel ring gear, diesel lift pump and gas and diesel fuel injectors, heater core assembly, radiator, radiator fan, radiator fan clutch or motor, ETA pump hose assembly, alternator, starter motor, electronic ignition module, radiator fan relay, fuel pump, starter motor solenoid. (our cars have NONE of those things)
What it does NOT include:
electric Vehicle’s main power cell batteries are not included in this coverage
or our actual drive train motors ???
and:
If You elected Powertrain Wrap Coverage, You have new PremiumCARE coverage for all components except components covered under PowertrainCARE. Powertrain Wrap Coverage applies only to the original Service Contract Holder for the selected coverage and is not transferable to any subsequent vehicle owner.
What am I missing?
It does include:
and:
What am I missing?
