taikajim
- Jul 10, 2021
- Finland
- EXAWD + KW V3 coilovers
Mine works 100% now with a swipe, locks instantly. I didnt even know you should press the lock (dont think there even is a sensor there?)
i used to have an issue where the driver door didn’t lock, but I had the door module swapped first, and then the driver side bt-antenna wiring (it measured a slight anomaly).
Try swiping down?
And if it’s only the driverside front, have them measure the antenna array impedances. The button only works if the car can position you at the door.
Try swiping down?
