DevSecOps
- Todd
- Sep 22, 2021
- Sacramento, CA
- '21 Audi SQ5 / '23 Rivian R1T / '23 M3P
- CISO
Preface:
I haven't seen anyone post a topic about a factory reset and I had never done one until recently. So, here's the things I learned, what steps you need to take and what to avoid doing. One day everyone will likely move on to another vehicle so this is probably something that you should be aware of. In time, this procedure may change, but as of 11/2023 this is how it's done.
Things to do before a reset:
Once you factory reset the vehicle you will be locked out of the connected services section of the Ford website. Therefore, it's important to first remove the subscriptions from the vehicle otherwise you won't be able to remove your credit card. If you factory reset and then attempt to remove your credit card it will say that the card is associated with subscriptions and you can no longer access those subscriptions so therefore you're kinda screwed. If you reset the vehicle first you'll need to add the vehicle again to cancel the services.
Log into the Ford website and go to connected services. Make sure that you cancel all of the connected services for the vehicle before resetting it. The BlueOval charge network is probably one of the most important ones to cancel because it has plug and charge. When I was testing this I was able to factory reset the vehicle and still plug and charge after the reset. Therefore, cancelling this service before resetting the car for ownership transfer is important. Once you cancel this service you should be able to remove your credit card on file.
If you have trials of BlueCruise, Navigation and Alexa you should be fine leaving those active since they don't actually have a billing profile associated with them until the trial ends.
What doesn't get reset?
When you perform a reset within the car there's a couple things that don't get reset.
In order to reset the HomeLink system you'll need to hold both the #1 and #3 buttons simultaneously for approximately 20 seconds until the light flashes rapidly. Once it starts flashing you can release the buttons and the system will be reset.
Resetting the Door Code:
In order to reset your door code you'll need to do the following:
Clear PaaK and Remove the vehicle from FordPass:
Go into your FordPass app and we first want to remove the vehicle from FordPass. If you reset the car first, you won't be able to remove the vehicle from the "garage". Go to your profile click on reset, scroll to the bottom and click on Remove Vehicle. You should get 2 email confirmations that PaaK was removed and that the vehicle has been removed from FordPass:
Factory Reset Within the Vehicle:
Now it's time to reset the vehicle. Go to your vehicle and click on the toggle icon (which Ford strangely uses for settings), then go to General and Reset. Factory reset can be found in the drop down.
You should now receive a couple more emails:
Follow Up Items:
On your phone remove the Bluetooth connections and WiFi connections.
If you log into your Ford account online you should see that the car has been removed. If it's still there then you didn't do the step within FordPass to remove the vehicle. There's a delete option within the Ford website, but it doesn't work. Therefore the only way to remove the vehicle would be to connect FordPass again and go through the steps to remove it.
Removing or Swapping EAP:
If you are in EAP you have the option to swap vehicles, remove vehicles or leave the program. You can login to the EAP program at https://www.earlyaccess.ford.com/ and it should prompt you to take one of those actions:
Deleting Your Ford Account:
Once all of the above items are done you can completely delete your Ford Account by going to:
{name} Account -> Account Settings -> Delete My Account
This will then ask you to confirm the deletion:
- The HomeLink visor settings do not get reset
- Your door code doesn't get reset
- PaaK doesn't get completely cleared out
- Enter the factory-set five-digit code.
- Press and release 1•2 on the keypad within five seconds.
- Press and hold 1•2 for two seconds. ...
- All personal codes are now erased and only the factory-set five-digit code will work.
Follow Up Items:
