FDRS - PCM reprogramming has failed
airspeed
Puerto Rico
Premium eAWD 2022
Hi there, I was trying to update my 22 Mach-E Premium with FDRS and while trying to update PCM module it reprogramming failed, now I am stuck. How I can fix that?
I am using TOPDON interface cable and Clore Automotive 100A for on-demand power supply.
Ford Mustang Mach-E FDRS - PCM reprogramming has failed PXL_20250322_163534637.MP~2
Update: I was able to install all updates and my Mach e is back to live.
1) My first mistake, I forgot to start the power supply mode in Clore.
2) After updating the TOPDON's Ford driver everything went smoothly in FDRS and I was able to install all the available updates.
Ford Mustang Mach-E FDRS - PCM reprogramming has failed PXL_20250322_180429806~2
airspeed
Puerto Rico
Premium eAWD 2022
When trying to update PCM, I get the below failed message.
Ford Mustang Mach-E FDRS - PCM reprogramming has failed PXL_20250322_170206392.MP
B177y
Olympic Peninsula, WA
Maybe you found a weakness of the non-Mongoose cable?
airspeed
Puerto Rico
Premium eAWD 2022
Another thing, I forgot to start the power supply. But not sure if that caused this problem, the first update I tried went smoothly.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Some updates just flat out won't work with knock off adapters. I'd suggest not updating your car with cheap adapters as they usually end up causing more issues.
rugedraw
Javier
Miami, FL
Auto Sales
It's the cable. What color is the PCM in FDRS now? Is the car drivaable?
rugedraw
Javier
Miami, FL
Auto Sales
Also, post the codes it is reporting.
rugedraw
Javier
Miami, FL
Auto Sales
That TopDon thing causes more problems than a toxic baby-momma. They are garbage.
rugedraw
Javier
Miami, FL
Auto Sales
I was able to fix it, the TOPDON Ford driver required an update.
Well, if you want to avoid problems, I would quit while you're ahead. I highly recommend you do not even try to update the IPMA, PSCM or CMR with it.
airspeed
Puerto Rico
Premium eAWD 2022
It worked fine after updating the cable software and ford driver, I was able to install all the updates smoothly.
benk016
Tulsa, Oklahoma
There are several people on here, myself included, that started with a knockoff adapter. It works okay until it doesn't. There are also some that were sending corrupted data back to Ford's database that can cause you issues later down the road. It is not worth the risk to save a few bucks.
Piolin
George
Europe
Mustang Mach E
Reset PCM. Release 12 v. battery sockets and try again. Remember to fit external power supply.
It happens the same to me when I programmed the IPMA.
Regards
