FiXED...No way to access the camera??
It works when in reverse, so I assume no fault.
BC uses the front and side cameras in conjunction with other sensors. It couldn’t hurt to see if @Mach-Lee or someone else with the tools can pull codes (if any exist). ?‍♂?
No IPMA codes seen.
I suggest they disconnect the 12V battery to reset all modules.
New2EV
New2EV
Palm Bay Florida
Charger, Explorer, Chevelle, Mach E
Here's the vin if anyone can figure out what is going on. 3FMTK3RM8MMA39268
I just really don't have time to mess with taking to a dealer right now.
New2EV
New2EV
Palm Bay Florida
No IPMA codes seen.
I'll give it until tomorrow and if the issue is still there, I'll try disconnecting the battery.
New2EV
New2EV
Palm Bay Florida
No IPMA codes seen.
No luck. No update overnight, so I disconnected the battery and left it for almost an hour. No change. Still no camera button. BC date still shows 2073.
New2EV
New2EV
Palm Bay Florida
FiXED!!!
I decided to see if there was anything forscan could do to solve my missing camera button issue. I re-upped my forscan license and connected my OBDII interface. The APIM has a setting called "Camera Soft Button" that was disabled. I enabled it, wrote to module and once Sync reset, the camera button appeared!!!
Wonder if this would work for the 2023's?
Ford Mustang Mach-E FiXED...No way to access the camera?? PXL_20230128_192703641
Now that I have a valid forscan license again.....time to see what else I can enable......:cool:
Thanks to everyone who tried to help. Really appreciate this forum and everyone on it!
