Nemshick_s
- Steve
- May 21, 2021
- Orange County, Ca
- Ford Flex, Kia All Electric Nero, Mustang Mach E
- Firmware Engineer, Technologist
Hi,
I had a ford 48A charger installed a while ago. It works fine. I noticed a couple of things:
1) For some reason, my MACH-E appears to not understand that I own one. It's in my Ford App. I have the extended range so when I get around 120 miles of charge left, the car tells me that it has to charge outside my charge time (I have it set to charge from 10PM to 9AM. Lowest Cost). When I change the car it does it within my time selection (Usually done fully charging around 4:30AM. I have the charge station set to 48A). My guess is that the car thinks the I have a lower amperage charger. Any idea how to fix this?
2) Using the Ford App, I select "Your Charge station". When I go into insights, it should show me what day I charged and how many KW I used. The last date it worked was Apr 19,2021-Apr 25,2021. Why is it not showing when I charge any more???
