FordPass High Battery Usage - iOS
Anybody else seeing high battery usage in the latest version of FordPass? Usually it’s only single digit percent, recently it’s been near 20% of my battery usage. Not doing anything special with it, and I try to keep the app quit as much as possible. FordPass 5.28.0 iOS 18.7
Ford Mustang Mach-E FordPass High Battery Usage - iOS IMG_1431
Ford Mustang Mach-E FordPass High Battery Usage - iOS IMG_1432
CarlSagan82
Mach E GT
5% is the highest I got two days out of the last week. I did update to ios26 the first day and noticed better battery overall.
Haven't noticed FordPass showing anything higher than single digits in the last 7 days shown on my phone. I've been using iOS 26 public beta since June but now on the latest regular iOS 26.0.1, FordPass 5.28.0 on my 17 Pro. I also have all settings in access turned on for FordPass
Ford Mustang Mach-E FordPass High Battery Usage - iOS IMG_8840
Ford Mustang Mach-E FordPass High Battery Usage - iOS IMG_8841
desiguy2447
Adam
Frisco Texas
2023 Ford Mach E Premium
Same here my Ford APP on IOS 26.01 was at 70% use rate yesterday. My battery drained by 11:30am to 48%. I then charged back to 68% and I had to charge the Iphone again at 4pm. From the Iphone forums I disabled backgroud App refresh on the Ford App. Checking this morning the Ford App is only at 1%. as of 7:53AM.
Ford Mustang Mach-E FordPass High Battery Usage - iOS Ford
Tampamike
Tampa, FL
‘24 Mach E Premium RWD
Mine was at 47%. My phone battery was low around 5 pm which never happens. I haven’t changed any settings recently and the car didn’t even leave the garage yesterday. Thought it was just sleeping soundly …
RoyHobbs
Rochester, MI
2024 Mustang Mach-E Premium
Yep, it’s definitely using ALOT more battery than before. I noticed it after an update about a month ago.
ah38k
Alex
OH, USA
‘23 Mach E CR1
Yeap, noticed it about the time I upgraded to iOS 26. It seems to have returned back to normal in the last few days though. I did force close the app and reopen it, this has helped in the past.
RoyHobbs
Rochester, MI
It happened on iOS 18 and iOS 26.
I’m fairly certain it started with the Ford Pass update 5.27.0 and continued in 5.28.0.
I’ve always had background app refresh turned off
Bad Dolphin
2024 Mach E GT
Another data point. I’ve noticed at times with iOS18 and a 16 pro high usage. I currently have iOS26 and 17 pro and the usage is not high right now.
Huh. I'm on iOS 18 and just checked. FordPass background usage is on and usage was 1%.
ProMax 15.
How did you guys get ios26 offered?
Bad Dolphin
2024 Mach E GT
iOS 26 has publicly available for a few weeks.
Thank you, RoyHobbs. Just found it at the bottom of the update screen.
Checked and it seems that many had problems including blue tooth/Wifi connectivity and overheating/battery drain issues. This may be because the phones had to re index everything and for some it went away after a few days. But others had to wipe their phones and reinstall from backup...
Did you have issues?
RoyHobbs
Rochester, MI
Zero issues.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Mine is up there too. It's currently the top battery user. Here's for the last 24 hours.
Ford Mustang Mach-E FordPass High Battery Usage - iOS IMG_5049
More shockingly, here's for the last 10 days:
Ford Mustang Mach-E FordPass High Battery Usage - iOS IMG_5050
I'm still running iOS 18.6.2. FP is version 5.28.0.
Hey Ford, what's going on?
