FORScan MME spreadsheet
Gullwingdmc
Chip
Boston, MA
The current sheet comes from Livinitup, who also did the F150/Lightning sheet. He has access to the Ford stuff that the rest of us don’t. If you wanted a living document, we might have to do a separate one. I could start one. I worry slightly about general public edit access. I suppose we could do a native forum table in a new thread, but I can’t see how to do multiuser editing.
Oh no I wasn’t saying have a user editable sheet. I was just saying use a separate form as a way for people suggests mods, then one person could add those to the spreadsheet. People could just post them here instead of a separate form, but it might be harder to keep track.
65JohnyevMod
Lindell Beach B.C. Canada
1956 Meteor sedan delivery,1965 Falcon delivery
The venerable Livnitup has graciously created a spreadsheet for the Mach-E. It only has a few modules at present, he will add more as he finds time. It is MY23, not sure of any differences with 21/22. The 2-press panic button mod worked for me.
Mach-E spreadsheet
Hello: IS the spreadsheet you have provided apply to a 2021 Mach-e ?
I have fitted a 2021 system to my 1965 Falcon and are trying to delete
unused modules
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
unused modules
Yes, most if not all of it applies to the ‘21.
65JohnyevMod
Thanks for the info. I have a big problem though, I cannot get the BCM to show when I open the FORScan to display modules and I cannot get to the part where I program modules even though my membership is still valid
tomtel
Tomasz
Poland
Mustang Mach-e GT Performance, Ford EDGE ST
mechanic
After the last update I no longer have GT animations on SYNC.
Maybe I need to change something in APIM settings? Splash Screen (APIM) I still have GT 7D0 03-01 504C 2202 07A2
Interestingly, the animation stayed on IPC.
Do you have the same? Is this a Ford change?
Elar
Peter
Hungary
Hello.
I am standing in a parking lot and the car is on.
I turn off the lights outside. But then the position light stays on.
Can I set it to turn off completely?
Ravensfan1996
Rick
2021 Mustang Mach E
The F150/Lightning spreadsheet has a Common tab, perhaps we should get similar added to the Mach-E version.
F150/Lightning Sheet
Note that it is possible for the module address to vary between those two and the Mach-E. If you are editing a module manually, double-check that the module address is the same.
Where is the Mach e spreadsheet?
65JohnyevMod
Mach-E spreadsheet
The spreadsheet you have supplied is great. I have installed a 2021 system into my 1965 Ford Falcon but I cannot get the high beam
lights to work although I have tried changing parameters with the FORScan . The IPC indicator lights when I move the dimmer switch but,
the lights turn off. I know this is not something people have usually done . Has anyone performed this sort of a swap before?
Thanks, J.T.
UN1075
2021 Mach E Premium Extended
Hey, I did my first ever Forscan mod! I was sweating bullets when I clicked write ?
I tried clicking through page after page in this thread to find common changes everyone are using. What are the top mods everyone does?
I'm going to do the Beosonic one after my DSP module gets updated.
Ford Mustang Mach-E FORScan MME spreadsheet PXL_20250215_134018887
LaFong
LaFong
Colorado
Systems Engineer
I have created a spreadsheet of common Forscan mods. It is very much alpha and not ready for publishing. If anyone wants to look it over, DM me and I will reply with a link.
noway
Norway
2021 Mach-E First Edition
Software developer
Hello.
DRL mode can be 1 or 2. One mode is DRL always on. Other is DRL (and all other lights) off when gear in park and light switch is on 0.
justalfe
alfredo
las vegas
21 Mach E select
Tech
id like to see it
65JohnyevMod
I would like to see the spreadsheet too ! Perhaps there is something there that would help me program my converted Falcon!
Thanks, J.T.
MadMatt
Montreal
2024 Mach E Select AWD
anyone know what this this does
D544 Speedometer Style (DSS)
720-05-01xxxx*xxxxx--0 =DSS Style 18 =DSS Style 3
4 =DSS Style 2C =DSS Style 4
