FORScan MME spreadsheet
rugedraw
Javier
Miami, FL
Auto Sales
Is there a change to disable or increase the “eyes away” when using both BC and cruise control?
No, that is hard coded in there for safety reasons.
Chapron
Detlef
germany
Mach e RWD EX TP2 / 2023.75
SAP Engineer
Hey, I am looking for a VIN of a USA 2023.75 with BlueCruise enabled with Assisted lane change. If we have one here please send me a PM oder just post it here. That would help me to configure ALC for my car.
Thanks in advance
rugedraw
Javier
Miami, FL
Auto Sales
Thanks in advance
I'll message you.
Chapron
Detlef
germany
SAP Engineer
Hello yall
I am still looking for an 2023.75 VIN with enabled BC and ALC.
My settings are so far ( thanks to rugedraw):
ModulAbkürzungCodeQ1Q2Q3Bemerkung
Accessory Protocol Interface ModuleAPIM7D0-09-05XXXXXX4X28xxAssisted Lane Change
Accessory Protocol Interface ModuleAPIM7D0-10-01XXXXXXXX10xxAssisted Lane Change
Accessory Protocol Interface ModuleAPIM7D0-10-02XXXXXXXX10xxAssisted Lane Change
Image Processing Module AIPMA706-01-02070000000017Assisted Lane Change
Image Processing Module AIPMA706-02-02XXXXXXXXX2xxAssisted Lane Change
Image Processing Module AIPMA706-38-01F8F8EXXXXXxxAssisted Lane Change
Any suggestions are welcome! :)
jmgreen
Joerg
Germany
Mach-E 2022 RWD-ER
Accessory Protocol Interface ModuleAPIMXXXXXX4X28xxAssisted Lane Change
Accessory Protocol Interface ModuleAPIMXXXXXXXX10xxAssisted Lane Change
Image Processing Module AIPMA070000000017Assisted Lane Change
Image Processing Module AIPMAXXXXXXXXX2xxAssisted Lane Change
Image Processing Module AIPMAF8F8EXXXXXxxAssisted Lane Change
Is your third line in the table just a "copy&paste error" of the second line, or do you really changed three addresses in the APIM?
Chapron
Detlef
germany
SAP Engineer
Ok i need to correct my copy. Thanks for the hint.
Edit: I just changed it to make more sense
rugedraw
Javier
Miami, FL
Auto Sales
Hello yall
I still believe (in the case of the vehicles in Europe) that there is something missing for it to work and changing the config in the IPMA alone will not do it. I believe that it is disabled somewhere in the GWM on purpose due to regulations in Europe. Unfortunately, there is no breakdown of GWM in the excel sheets for us to go through and try to figure it out.
Chapron
Detlef
germany
SAP Engineer
Ok that may be the reason why. If i get a 2023.75 VIN from the us i could check the diffrence in gwm compared to mine. Maybe its not as diffrent then ours In the eu. If the gwm can be decoded in the same way as the other modules.
rugedraw
Javier
Miami, FL
Auto Sales
I am sure it can be decoded, but Livnitup did not and will not do it. There is way too much sensitive info stored in the GWM and Ford would lose their minds if he did. However, you can compare the data between the two, but it is a lot of data to go through.
Even then, it may be more than just config. It could be the software itself in the GWM that does not contain the events for lane change. If that is the case, changing the config will do nothing.
jmgreen
Joerg
Germany
Mach-E 2022 RWD-ER
Can someone please explain me the following function within the IPMA:
There are quite a lot of customer settings, e.g. CustomerSetting_xxxSelected_Pers1/2/3/4.
My understanding is that those are settings within the APIM for a specific feature (xxx = on/off) for four separate driver profiles.
But together with the four profile settings there is also a CustomerSetting_xxxSelected_Vehicle. What is this doing?
Is this a fifth profile (the user manual says something about a guest profile)?
Or is this one required to enable the feature overall in the car (i.e. if not set, then also the four customer profile settings are off)?
buddabest27
Italy
Mustang Mach-E 2021 Select RWD Extended Range
It's possible enabling charge speed on a Mach-E 2021 like on 2025 model?
I have 23291 as software version..
Jmurphy7414
Ohio - USA
2021 Mustang Mach-E (Job 1)
Has anyone found a way to change the sequential front and rear blinkers? In the US, the light bars start at full and shrink. In European models, the lights grow outwards until they are full. I prefer the European style. Is there a FORSCAN mod that can allow for this?
ave
Finland
Mach-e GPTE '21
I would be more into disabling UFO sound than backup sound. Is it the same speaker?
Hello
It is the same sound system. In the trunk PACM module there are two samples, the humming sound and the garbage truck reverse beep sound.
The drive mode and speed determines what sound goes out to the speaker line.
Long story short, I have disabled the beep beep stuff on mine but kept the hum.
The sample data is in serial flash rom and while it cant be freely manipulated, it is possible to corrupt it so one specific sample is not used at all.
Chapron
Detlef
germany
SAP Engineer
Whould you be willing to share how to do that?
ave
Finland
Mach-e GPTE '21
I have been considering publishing all the findings, haven't done so yet.
It is a bit involved process, for now you have to take the module out, take it apart, clean off some protective coating, dump the rom contents using debugging tools, alter the data, then flash the new data in
Ford Mustang Mach-E FORScan MME spreadsheet 1769692918674-04
