FORScan MME spreadsheet
jav_eee
Javi
Edinburg, TX
2025 Mach-E Select
Energy Industry
Hi, great post! I own a 2024 MME (Europe) and I've been able to make some mods through Forscan, but there are some of them that I couldn't:
- Keyfob location: I've set 00C0 FFFC 3F74 in BCM 726-06-07. Doesn't work.
- High beam ramping: in my car, the HCM 734-01-04 value doesn't even exist.
- Pedestrian and backup sound: 720-09-02 X*XX XX -> my value is BF2D A1BF, not 4 or 5.
Those which work:
All chimes disabled
relock if door not opened
silence mode switch
cameras on when moving (although it only shows reverse camera)
GT Power meter
Double horn if cabin left.
Tilt mirrors in reverse
Just in case anyone can help with those that doesn't work or need help with the others.
Silence mode switch?
MVasco
Manuel
Spain
Mach-e 2023
Yeah, I read it in the f150 sheet, but it does work on my car too; "it adds a toggle in sync under settings, vehicle (prevents any approach lighting, lock/unlock lighting, courtesy lights until truck is turned on). APIM 7D0-09-02 *XXX XXXX XX (add 1 to current value).
I haven't tested it, though; only checked that the switch is here.
Jeff-NoVA
Jeff
Northern VA
2022 Mustang Mach-E Premium
Those which work:
GT Power meter
Unless something changed very recently, or you are behind on your updates (possibly due to European cars receiving updates at a different cadence?), GT power meter works in the sense that you can make it appear but it just shows jail bars so it’s useless
Chapron
Detlef
germany
Mach e RWD EX TP2 / 2023.75
SAP Engineer
@ MVasco: Hey do you have the code for 706-01-02if u have activated BC?
MVasco
Manuel
Spain
Mach-e 2023
Well, I still don't know how to be sure of your updates; latest one for me was this about the doors being locked in some situations.
Besides, GT power meter works perfectly in my car, and the blue/green bar moves as long as I brake/accelerate.
Yes, for me it was: 0600 0000 001F.
Piolin
George
Europe
Mustang Mach E
Buenas, Manuel:
¿Te funciona la barra de potencia correctamente, es decir la parte verde y la parte azul? ¿Qué modelo y año tienes de MME? A la mayoría, desde una actualización del PCM anterior, no nos va la parte de potencia (azul) de la barra.
Ya nos dices.
MVasco
Manuel
Spain
Mach-e 2023
Buenas, Manuel:
Ya nos dices.
Sí, perfectamente. Mustang 2024 SR RWD Base con pack Tecnología.
Yes, completely. I have a 2024 Mustang SR RWD Base with technology pack.
Piolin
George
Europe
Mustang Mach E
Ok, thank you for your answer.
Just 0600 0000 001F on IPC module by using ForScan? No more things?
Regards
MVasco
Manuel
Spain
Mach-e 2023
Regards
Sorry, I don't get you. This is supposed to be for ALC, but I haven't been able to test it yet.
Piolin
George
Europe
Mustang Mach E
Good evening:
I was wondering about the code you entered to display the power bar. By default, it only appears on GTs.
Most of us don't have the acceleration zone working, and it appears gray.
Let us know.
Best regards
MVasco
Manuel
Spain
Mach-e 2023
Ford Mustang Mach-E FORScan MME spreadsheet 1755173049582-f9
No, the change is as in the screenshot: IPC 720-11-02 VALUE to X2xx xxxx
Good evening:
Let us know.
Best regards
Chapron
Detlef
germany
SAP Engineer
@MVasco
do you habe assisted lane change activated for Bluecruise with that code?
MVasco
Manuel
Spain
Mach-e 2023
@MVasco
Well, I'm not using it these days as I'm on my holidays. Don't even know if I will use it because BC subscription is due at the end of the month
Chapron
Detlef
germany
SAP Engineer
@ MVasco: "Besides, GT power meter works perfectly in my car, and the blue/green bar moves as long as I brake/accelerate."
Which code in what Modul did u use? I like to get that as well :cool:
Thanks in advance
MVasco
Manuel
Spain
Mach-e 2023
