FORScan MME spreadsheet
lanebk
Warrenton, MO
NQY 2022 Mach E Premium ER AWD
AH64LCT Test
Is it possible to change the tolerance for the speed control under Adaptive Cruise Control from MPH to a percentage? I've looked through the settings in forscan but haven't found anything. I'm hoping the someone that has spent more time than I have looking through the settings might know.
Suitsandty
Tyler
Kentucky
2021 Ford Mustang Mach-E Premium
Training and Recruiting Specialist
Well everyone it’s story time…
I have 2021 Premium, since I got it in January of 2024 I have not had blue cruise available. After 5+ trips to the dealership, hours on the phone, countless follow up calls and tickets…still no blue cruise (escalations, TAC team, regional managers…nothing). It’s never showed up in my connected services, and never activated in the car. So I was connected with @rugedraw and my adapter arrive tomorrow to change literally 2 things in FORscan. Being part of this community has been great and my passion for modding cars and tinkering with things has been reignited. I just want one of the main reasons I got the car to just work…
So eager to see if this does work. Will update everyone tomorrow and share everything at that time for what I did to fix my problem.
rugedraw
Javier
Miami, FL
Auto Sales
It can be fixed and then some. ;)
Arjan
Arjan
NL
Ford Mustang Mach-E GT Performance
Right, I saw that... but that just has the full module config list. Over in the F150 forum we also have a tab that has known mods on one page so others can apply too. See below.
Here is the link to the F150 spreadsheet from Livinitup to view the full thing.
https://bit.ly/3cJnYMS
Does anyone know if the pedestrian alert speaker config is also under the glovebox (like in the youtube video of the 150) in the MME ? Sounds like a good solution.
Arjan
Arjan
NL
After looking into the preconfigured settings that Forscan can do, i noticed that i can enable lane assist. Has anyone tried this yet ? Without paying for Bluecruise ?
Dysan911
2023 Mustang Mach E GT
Technical Software Analyst
Not sure on that but I disabled mine with a product that you just unplug the PWS speaker and plug the device into the harness. It fools the vehicle into thinking the PWS is still connected.
I don't mind the low speed sound. It was just the backup Garbage truck beep that drove me crazy. If there was a way to disable that, I'd only do that. The Device I have takes out both though.
Aulander
Italy
Mustang Mach-E Premium AWD
I made a list of all the preconfigured settings of APIM and IPC modules that can be changed with Forscan, for anyone who wants to explore some hidden settings that can be enabled or tested on our cars. Some of them are shown in my language and many options are made for different vehicle models and cannot be applied on the MME.
I already enabled on my MME MY21:
- Beosonic equalizer (needs also DSP as-built format change)
- Walk Away Lock Audible Feedback
- Lock Audible Feedback
I tryed to enable "Blind Spot Monitoring 2.0 - Chimes" and "Chime for Speed Limit Change (Speed Limit Assist Menu)" with no result (don't know if additional settings are required or not possible on MME).
But I found also:
- "Comfort Pet" in APIM (is it a pet mode?)
- "Battery Voltage Display" in IPC (is it the 12V battery charge indicator?)
but I haven't tryed yet.
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
But I found also:
I do not see Walk Away Lock Audible Feedback in our current Mach-E Google sheet. Did you get some of these changes from elsewhere or from a different model, e.g. Lightning? Could you post the module numbers and values?
Dysan911
I thought we already had audible feedback on walk away locks and didn’t need to use forscan for that one.
LaFong
LaFong
Colorado
Systems Engineer
Huh, I guess there is. Mine was disabled.
Dysan911
Yeah I only happen to remember it because I didn’t care for the loud single honk and decided to disable mine.
Aulander
Italy
The settings to enable, editing in Forscan the APIM module (without as-built) are:
Ford Mustang Mach-E FORScan MME spreadsheet apim
- Walk Away Lock and Walk Away Lock Feedback
- Locking Feedback Audible and Locking Feedback Visual
These enable horn and lights with Walk Away lock and also with Key lock. The audible settings are not as-built in EU, maybe they are in US.
Mark Hassa
New Westminster, BC
2024 Grabber Blue GT
Government Food Inspector
I think other countries outside of North America have walk away lock disabled. I believe the UK has it disabled for some reason.
