Friggin "music" turn off ?
Don_23805
Don
Central VA
Honda Ridgeline, Prem MME DMG AWD Ex Batt
is there a setting to turn off that inane noise that plays whenever the door is open?
TIA
Don
TIA
Don
It's a warning chime. It's alerting you to an issue. The issue is that your headlights are on. SImply rotate the knob from AUTO, to OFF, then back to AUTO. The switch has bad firmware, and will be replaceable by a dealer in July, maybe.
Music? First time I've heard that.
Don_23805
Don
Central VA
Thanx, that seemed to work. Too bad Edsel doesn't concentrate on Real issues rather than offering more stupid games. If I wanted a friend, I'd get a dog!
Yeah, because having your headlights drain your battery so you can't drive the car isn't a real issue.
ThomF
Thom
Milwaukee East Side
www.fehring.us
Ford Mustang Mach-e
Engineer-historian
This headlight 'bug' needs to get fixed by Ford. It seems that every update causes the headlight setting to be ignored, such that headlights stay on until the switch is moved back to its automatic setting. I've had it occur at least three times now--once at the dealer following service.
There is a fix, a new switch. It is supposed to be at dealer's in July. Then, they have tens of thousands of replacements to do (I would guess).
There are some Lightnings also. And I would expect other models.
Don_23805
Don
Central VA
. . . and I must have gotten an update last night. How do I know? All my radio presets disappeared, and it was at the bottom of the AM band. Thanx again Edsel Ford
