Going in for service. What software updates do I need?
BTW, I took Marlin in for a Monday reservation (Dec 6), got him back on Thursday (Dec 9). Apparently they had trouble getting some of the modules to install and had to try it repeatedly. They said they finally got them all
This will be a problem for Ford to get PowerUps to work in the future, especially for complicated installs. It makes sense that Ford has so far kept each PowerUp to a module or two.
What did they say about your windshield and roof? I remember you said they wanted to inspect them first?
breeves002
St. Louis, MO
2021 Mach-E GT PE
Thanks!
I had a look on it.
Is that all I need? Entering the VIN should then return complete status of the vehicle updates?
Yes that is correct. You can run the updates too if you have a J2534 OBD adapter.
MerryBrown
Mary
Northern, CA
2018 Ford Escape, Red Ford Mach-E on order
Finance
Mine went in yesterday. I had the recall paperwork for the seal for the roof glass, but the tech didn't even want to see it. He said he had everything in his system. I don't think I have much confidence in his abilities. He talked a lot about the software updates which I also need, but didn't mention the seal. He said the software updates would take many hours "each." After reading a few threads here I am not sure he knows what he is talking about and I wonder when I will get my car back... He also said I would get updates from him and I haven't heard a thing. sigh.
MerryBrown
Mary
Northern, CA
Finance
Yup, as I suspected, it' has now stretched from one day to two, might be more. They are having issues with the error message I got. I was driving in traffic when I got the message "SERVICE NEEDED, STOP CAR." I couldn't pull over at that minute because I was in the thick of traffic and then a couple minutes later it just shut off. Fortunately it let me roll to the shoulder. I turned everything off. Sat there trying to figure out how to call the tow people, and thought I could find the number in the system so I tried turning the car back on again and it ran like a charm. I drove home and called my Dealer for the appt. This is the error message they can't fix today.
dixiekidd88
Joey
Charleston, SC former Bay Area, California
21 Prem XAWD, 23 Prem XRWD, 23 Lariat Hybrid F150, 20 Black Label Navigator
We had the same issue, ours shut down on the highway with no warning on Christmas eve. The latest major update was done on 12/20. We were stranded 6 hours from home thankfully family was only an hour away but it was 3 1/2 days until we could get a rental, and it had to be towed 2x's. The car would not start once we pulled over, had 'AWD NOT AVAILABLE, SERVICE ANDVANCE TRAC, STOP SAFELY, SERVICE SOON' all indicator lights showed up. After a few minutes it completely died and could not open doors from the outside. The high voltage battery still had 27%, and now it sits at a dealership awaiting diagnosis. Apparently the 'tech called in sick' after seeing it on Monday and attempting diagnostic......It has become frustrating since this is the second time this same issue has happened.
PatrickDB
Patrick
Belgium
Mustang Mach E
I have to get my new MME at the dealer this afternoon and I would like to know whether all updates were installed. Unfortunately too late to buy, install,... FDRS license to check for myself.
Therefore, could anybody check what updates my car has had?
VIN isWF0TK3SU4MMA55672
Much appreciated!!
mylittlepony
Dominick
Fallbrook
MachE
Will the recall replace the windshield or just use a new sealant? I have an IR tint on the inside windshield so will I need to get another tint done or will they use same one?
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
Unless they break it during the process you will not get a new windshield.
MerryBrown
Mary
Northern, CA
Finance
So it took 3 days but the software was updated.
They said I will have to bring it back for the seals. They bring in someone from a glass specialist to inspect it then that person will be installing the seals. that will be taking another couple days.
I am a little bit worried about this. They are going to take off the entire top glass roof. I haven't had any trouble yet. I am afraid that this might cause some later.
