Groove concrete Highway
01250al
gabriel
houston
mach e select
employee
I just took possession of a Mach E Select and everything was going well until I drove a Grooved Highway like the one attached. Apparently it is to drain the water but... Mach E goes out of control at any speed. It's almost not safe, has anyone experienced this? I turned everything on and off thinking it was adaptive driving or lane keeping radar, but nothing worked.
Ford Mustang Mach-E Groove concrete Highway IMG_5883
LordWino
Houston, TX
2023 MME Premium ER AWD
I had to check if you were in Houston when I saw this. I had the same problem when I bought both of my MME's. When the tires wear a little the problem will go away. You definitely have to pay more attention until then though.
What do you mean by “it went out of control”? Like the grooves are grabbing the tires?
hybrid2bev
2026 Rally
That's not specific to the Mach-E. It's the interaction of the groves on the tire tread and the groves in the pavement. It's normal for the interaction to feel a bit wobbly especially if your tires have groves that run parallel to the groves in the pavement.
Ford Mustang Mach-E Groove concrete Highway 1726769146753-yv
When I bought my Blazer it was a serious handful on grooved roads. It behaved like the ball joints, tie rods, and steering box were worn so far out that they all should have been making clanking noises. When I corrected inflation pressures, it became docile and predictable. ?‍♂?
Ford Motor Company
Official Ford Account
Hi there! This concern doesn’t sound like something we want you to experience. Please send us a private message including your VIN and local Ford dealer so we can investigate further. Thanks!
VindictivePantz
Arlen, TX
2021 Mustang MACH-E Premium AWD w/ Ext. Battery
It is much worse with real AWD. My other car (Audi) moves back and forth like there's a strong crosswind.
Blame NASA.
YeOldeTraveller
Clark
Ann Arbor, MI, USA
2024 MME Rally
I remember when they started to groove highways. The comparison was to the grooves on runways. Thing is, the grooves on runways are perpendicular to the direction of travel, not parallel. If highways were grooved in the same manner, they would move water better while not causing directional issues for the drivers. I assume we cut them the way we do as it is much easier (read: cheaper) to cut parallel grooves.
phil
LS400
Blame NASA.
Interesting that they measured grooving's effect on reducing highway accidents during wet weather only. Makes me wonder whether accidents increased during dry weather. They probably didn't even ask. Better to simply declare victory and move on.
VindictivePantz
Arlen, TX
I noticed a bit more with my CC2s than I did the OEM tires. It's annoying, and sometimes loud depending on the grooving and exact type of mix used, but my MME is more tolerable.
The lines do make potholes easier to see, which is helpful in the Chicago area :)
Schmedlack
Dundalk, MD
2014 Ford Escape S 1925 Ford Tudor (2-door)
Trader
Try riding a motorcycle on a grooved pavement and see what happens.
Bruboy
Bruce
HTX
Semi-retired
Interesting, as I live in HTX. That was one of the first things I noticed when I got on 290, the road about ripped the car out of my hands. I am thinking that the wider tire setup I go with in the future will help.
Really?
Are you going to collect the VIN for the road surface too?
